MSH. It depends. If it is just a powersupply (not controller) and it has wires connected, the wire with the "white stripe" is the positive lead. If it has "lugs" or "screws", then, using a multimeter, the "red" wire on the multimeter is positive, black is negative, and you have it the right way round when you get a "postive" reading from the lugs.
If it's a controller, then it doesn't really matter, as the polarity will be reversed when you switch directions.
