Which HO Track do you use a majority of?
  • Code 100 Store bought (atlas, bachmann ez track, flex, etc...)
    Votes: 14 33.3%
  • Code 100 hand laid
    Votes: 1 2.4%
  • Code 83 Store bought (atlas, Walthers, flex, etc...)
    Votes: 19 45.2%
  • Code 83 hand laid
    Votes: 2 4.8%
  • Code 70 Store Bought?
    Votes: 0 0.0%
  • Code 70 Haid Laid
    Votes: 3 7.1%
  • Combination of 100&83
    Votes: 2 4.8%
  • Combination of 83&70
    Votes: 2 4.8%
  • Combination of 100&70
    Votes: 1 2.4%
  • Whatever came with the set?
    Votes: 0 0.0%
  • Don't Know?
    Votes: 0 0.0%
  • Don't Care?
    Votes: 0 0.0%
  • Total voters
    42
  • Poll closed .
Just curious to find out with all the new track options what the majority is using. To many choices. I still choose Code 100 because of the old Rivarossi engines in my collection. Those big flanges need some place to go! Besides with good weathering it really looks good. Comments?
You can choose more than one answer in the poll if need be.
shaygetz
3,612
www.freewebs.com
Same as you, C100...I have some European equipment that doesn't like the finer rail. On the bright side, certain stretches of the Pennsy had rail the was 135 pound---that would scale out to C100.:thumb:
jeffrey-wimberl
2,564
Sundown, Louisiana, USA
I use all nickel-silver Bachmann EZ track. I've heard some horror stories about it (constant derailments and such) but after further investigation I usually found out that the person submitting the horror story didn't lay the track right in the first place. For some reason people think that they can simply pop the track together and throw it down anywhere and expect it to work flawlessly. It won't. Like all other track, it has to be laid properly, with no kinks, bows or dips. This is important for steamers, diesels are much more forgiving.
darkcurves
154
I would definitely go for Code 100. I have seen Code 83 and 100 side by side, cant really notice the difference.
MadHatter
Charging at full tilt.
Jan 27, 2007
1,034
2
Centurion, South Africa
Piko (German brand pronounced like the English Peco) make a code 83 track that is the same height as code 100 but thinner.
I want to use code 100 for my mainlines and code 83 for yards, sidings, etc.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Most of the layout is code 100 Peco salvaged from previous layouts or bought before their code 75 came out. My last expansions were Peco code 75. I also have some British fine scale (bullhead rail) from SMP and C&L.
I do have a number of locos and cars that object to the finer track, and I did use it on both of my outlying stations.
FiatFan
191
2
I use Atlas code 83 track and switches. Next time, I may hand lay the switches. I really don't like the Atlas frogs or hinged point rails.
Tom
Relic
366
Nova Scotia
Yes I use Atlas c-100 rail but I think if I were to start over I would use the 83.
Like everything else when I decided to do model trains I jumped in full tilt,no research,just buy stuff and hope for the best,the trick is to get in too deep to back out,not that I want to quit, it's a great hobby, that's just the drum I hear.
santafewillie
227
era tx
I use Atlas code 100. That's what was most available when I started and after it's weathered no one really notices that it's a tad too big. I can't afford to change now and don't want to rip up 300' and 85 turnouts.
Mastiffdog
137
When I modeled in N scale back in the early 1990's I used Atlas track and switches. When I started HO in 2003 I started with Walthers/Shinohara Code 83 Flex and Switches. Then I tried Kato Unitrack for a layout and although it worked great, I just couldn't live with the plastic built in ballast, so I went back to WS Code 83.
My current layout is WS Code 83 spiked on to Homabed (Homasote) pre cut roadbed.
L
lester perry
As of now I use 100 but in future I will be useing 83. And there will be a future addition to my layout. I am collecting lumber now to add to the building.
Les
