when is a layout to big
Discussion in 'Getting Started' started by scoobyloven, May 14, 2002.
  1. Too Big??? Never
    scoobyloven, look at at this way, you have a whole lifetime to build and add on, and no limit to area, wow I thought I was lucky when my wife agreed to let me have our 12 x 16 barn (Shed)... seriously you should have great fun for many years... Being a Michigander It would be interesting to see your barn once you get started. Here is a picture of my Train Barn, Taken last winter during a storm in nearly 2 feet of snow.... Ive installed an air conditioner, and will be just starting the benchwork this week. Lots of luck. planeshavings42
  2. Tyson Rayles
    Tyson Rayles Active Member
    Air conditioner????????????? :confused: I think Mother Nature has already took care of that from the looks of that photo!!! :D
  3. Drew1125
    Drew1125 Active Member
    How about a rotary plow?! :D
    BTW Tyson,
    Pole barns have gotten a little more modern these days...you can get them in a kit form, with pre-cut poles, metal framing, & siding.
    My brother-in-law lives in one! :rolleyes:
    See? Not all us rednecks live in trailers! :D
  4. rockislandmike
    rockislandmike Active Member
    Sweet ! I'm not sure which I'm more jealous of - the pole barn or the air conditioned shed....................................................
    PS have we seen a trackplan planeshavin' ???
  5. gromit
    gromit New Member
    You sure those dimentions are correct? That's over 86,000 square feet, that's more than 5 times the size of my yard, which is only 50 x 150 feet. I find it difficult to believe you have something that big in the back yard in a residential area. Sounds more like a commerical sized space to me.
  6. cidchase
    cidchase Active Member
    you should definitely look into NoTrax (see April Model Railroader)for a layout this size
  7. kettlestack
    kettlestack Member
    I'm still gasping at the enormity of it all.
    Does this mean we will have a two week reunion at your place and bring our woodworking tools with us? ..:D :D
    I'm cheap to run, only 2 cans of beer a day and a coathanger for bedding down for the night! ... :D
    Seriously though, you are one lucky fellow and you have already made up your mind as to settling for a shelf type RailRoad (I was going to say "pike" or "layout") empire. Your options and opportunity just blows my mind.
    I wish you great success with such a project (the Southern RR gets a new sub-division) .... (chuckling).
    heh heh heh, And by the way, your wife is quite right! :D .
  8. 60103
    Pole barn -- thanks
    Thanks for the pole barn info. Don't know if I've seen one or not.
    (I was thinking of somrthing from a trolley line -- there's the car barn on that side of the yard and the pole barn at the back.)
  9. Tyson Rayles
    Charlie those kits are for sissy's, us real red-necks still do it the hard way. Mainly cause we can't afford the kits, what with having to maintain the wheel bearings, lights, brakes, etc. on our homes :D !!!
  10. Drew1125
    Y'all's trailers got wheels on 'em?
    Ar's gist sits on cinder blocks, and's got a lean-to on th' back! :D
    And you know fer shur yer a redneck if your front porch collapses, & more 'un 6 dogs are kilt! :D :D :D
  11. scoobyloven
    scoobyloven Member
    yes i am for sure on the space i do it five or six times and came out with the same numbers... it was used to store and work on farm equipment in the winter and it is made out of those kits only thing it don't have is ac but all i would have to do is open the doors.. as for the track plan i'm going to start that this weekend when i get my bigger hard drive to put it on i did pick out on part of it it would be out of the book101 track plans it is plan 99... and plan 95on the left side and use that for a starting point
  12. Drew1125
    I was going to suggest that book, & also one by John Armstrong called Creative Layout Design, which also has quite a few ideas for utilizing large spaces.
  13. scoobyloven
    scoobyloven Member
    thinks charile
    i don't have that one from john armstrong but i would check it out
  14. Tyson Rayles
    Yaeh Charlie, go ahead and flaunt the fact you'un's are rich and afford lean-to's and dogs! If I want a pet I gotta borrow the neighbors cat :D !
  15. kettlestack
    kettlestack Member
    You guys are killing me!!!!!!
    Just spluttered 1/2 a pint of beer over my keyboard at thet thar Southern speak Charlie! :D :D
  16. Drew1125
    Shoooot, Errol,
    That's 'zactly why we got 'dem dogs...ta clean up th' mess when we spill ar beer! :)
  17. I'm starting with an up and over dogbone It's in atlas trackplan book and is number 12. Aproximatly 50 ft of track, but I'll expand in both directions, My bench is a U shape 4ft wide 12ft long on both sides with 12ft across the back. So I have plenty of room to expand. I should have the bench's in by the weekend, and then the real fun begins... Did I say fun??? Will post some pic's when I have the track nearly complete. Planeshavings42
  18. scoobyloven
    scoobyloven Member
    don't know about you all but my dog don't clean up any mess it makes the and the cat cleans them up but as for that southern talk i lived down south for 5 years then moved back north where pepole talk so i can understand them... and they don't say over yander, wendew and can't forget you all :p
  19. Air Conditioning
    That Photo was taken in January, here's one taken today
    Planeshavings42. Ps the air was on today when I was working out there.
      File size:
      12.5 KB
  20. Drew1125
    I used to travel up around the Great Lakes region a bit...so you know as well as I, that "rednecks" can be found on BOTH sides of the Mason-Dixon.
    I might even add, for Errols benifit, that I spent an evening drinking Jack Daniels, & smoking Marlboros with a couple of them in a pub in Glasgow, (Scotland The Brave, that is) many years ago. Felt right at home, I did! :)
