Mummert, using two powered engines will definately help. Also, make sure the track and loco wheels are clean and dry ( no oil or cleaner residue ). Another trick if you can do it, is to add weight to the loco. It also depends on the brand of the loco and if both trucks are driven. (assuming you are using diesels )
Loren
