What's with the Angled thing?
Discussion in 'The Real Thing- North America' started by MilesWestern, May 15, 2006.
  1. MilesWestern
    MilesWestern Active Member
  2. liven_letdie
    liven_letdie Member
    I would take a stab and say its a clearance car to check tunnel height/clear tunnel debris but Im no expert. :D
  3. eightyeightfan1
    eightyeightfan1 Now I'm AMP'd
    Looks like it might be an Aircraft Part car. Boeing has a few of them, that they haul major assemblies of aircraft from one plant to the final assembly plant. Looks almost like a nose section being transported.
    But..Like Cory...just a guess.
    Looking through the rest of the pics, the flat car with the shrink wrapped "Pipe", looks llike it might be a section of fuselage, either the top or bottom half.
  4. Sunburn
    Sunburn Member
  5. Russ Bellinis
    Russ Bellinis Active Member
    I'm not sure, but it looks like a container on a flat car in your pic. I'm sure it is aircraft parts. I suspect Boing has some parts containers that are bolted together with a flat like an autoparts car for large assemblies. It would appear that your pic is of a container designed to carry a smaller assembly like a cockpit section and then loaded on a flat car.
  6. ross31r
    ross31r Member
    ii would think its probably a combination of things, firstly an aerodynamic buffer for the aircraft fusealage (otherwise there would be incredbile drag and possible damage to the interior of the fusealge during transport) and i would assume that perhaps the rear end has doors to allow it to be loaded to carry some of the smaller odd shaped parts for the aircraft - i doubt that includes the cockpit as this is an intergal part of the aircrafts frame, not a removable sectiona and as such is part of the main frame assembly.
    It would normally run (from the pictures i have seen) coupled the other way round ie wedge shaped end away from the camera with the the flat car in front of it and another identical unit coupled facing the way the one in the camera is pointed coupled to the opposite end of the flat car.
    like so
  7. Mellow-Mike
    Mellow-Mike Member
    It's a BNSF idler car, which accomodates the overhang of a full Boeing 737 fuselage that's mounted on an 89' flat. The structure at the rear generally contains parts to the same aircraft. These trains run from Kansas City to Seattle. I only got off the one pic, as the train was moving fast, and I had to park at the bottom of an overpass, and run up the sidewalk as the train was going beneath. Hence the blurry quality. (I wanted the overhead view, rather than the side view).
    The link that ross31r posted above is a perfect shot of the loaded combo.
