What's the correct size Xfer for a Lionel G Engine?
Discussion in 'G / O / S Scale Model Trains' started by TedTrain, Nov 12, 2008.
  1. TedTrain
    TedTrain Member
    Hi ALL!
    I got a Conrail GP-7, G Scale Lionel train at a Tag Sale. I'm trying to run it on a Tyco HO transformer, it does....sort of. Runs slow, the light works, rail Sounds work too. So, what's the correct size Xfer?
    Thanks, Ted
  2. nkp174
    nkp174 Active Member
    Check out the MRC transformers...such as a Tech 2 or Tech 4. Large scale trains run on higher voltage than HO. 18V or 24V I think, versus 12V for HO. They are DC (unlike Marklin and older Lionel). In addition to the voltage determining the speed, a powerpack has to have enough umph (VA) to keep your motor turning. MRC ran an add on the back of Model Railroader, for seamingly decades, of 15 locomotives on a Tech 2, where your Tyco pack might start to smell funny with 3 locomotives on it.
    I use either a Tech 4 220 or an MRC Control Master 20 for my LGB stuff.
    Hope that helps
