Christmas is over, and I have some cash for tools.
My plans are to built masters for HO NKP passenger cars, On3 DSP&PRR passenger, and On3 DSP&PRR freight cars...and then use these masters to produce molds for resin castings for major assemblies: sides, interiors, etc...
I also plan to do some locomotive scratch building. For the NKP, I first would like to build an NKP pacific (there's a thread on here about it) using a genesis mechanism...and later an R class 4-6-0 with 72" drivers from bowser. For the DSP&P, I intend to scratch build a 4-4-0 #2, Platte Canyon. This will require a lathe for making the drivers, and possibly the domes too. I also plan to scratch build a mason bogie using drivers and castings from PSC & Grandt Line. I'd also like to eventually add a Cooke Mogul and a Balwin 2-8-0...purchased/kitbashed/whatever.
I have: a mill file, jeweller's files, triangle file, a bastard file, a digital caliper, x-actos, razor saws, a rotary tool, an airbrush, a paper cutter (for styrene), cork board for jigs, normal hand tools (hammer, needle nose pliers), small drills and a vise.
So, how should I use my $500?
My initial thoughts are:
Alumilite Super Casting kit ($60-70)
Scroll Saw ($40-80)
Jewelers saw
Raw materials...brass/wood/styrene
Save the rest of the money for later
Later:
mini lathe ($350-450)
micro mill ($260)
resistence soldering unit ($?)
Air compressor ($60)
Sand blaster accessories ($30?)
Eventually;
CNC Machine
Would a micro-mill (from Harbor freight) be able to do most of what you'd usually use a drill press and scroll saw for? Would I be able to expect that I could do a decent job cutting windows for passenger cars? Would this be slow enough to avoid melting styrene if I tried?
If so, I'm inclined to get one of them along with the resin casting kit and raw materials.
My engine construction plan if I had all these tools:
DSP&P 4-4-0
NKP 4-6-2
DSP&P 2-6-0
DSP&P 2-6-6t
DSP&P 2-8-0
NKP 4-6-0 (R class)
Since I don't have the lathe:
NKP 4-6-2
DSP&P 2-6-6t (Drivers are around $35 for a set...I already have the domes)
DSP&P 2-8-0
DSP&P 2-6-0
NKP 4-6-0
Currently I have a Bachmann Mogul & a Grant Line porter to power my 4' of On3 railway.
I'm a grad student in engineering, so I have free access to CAD...and I'm comfortable doing any calculations I need for my trains.
Please share your wisdom
Scroll Saw ($40-80)
Jewelers saw
Later:
micro mill ($260)
Eventually;
CNC Machine
DSP&P 4-4-0
NKP 4-6-2
DSP&P 2-6-0
DSP&P 2-6-6t
DSP&P 2-8-0
NKP 4-6-0 (R class)
NKP 4-6-2
DSP&P 2-8-0
DSP&P 2-6-0
NKP 4-6-0
