I saw right off that radius was going to be trouble for you.
Get yourself a #8 left hand turnout and make your own curved TO.There is an article on doing this somewhere but suffice it to say you will be trimming away pieces of plastic underneath similar to a piece of flextrack.The longer turnout will make this a bit easier than trying to do it with a standard TO.Use your NMRA trackgauge as you tack this down.THIS IS IMPORTANT!! (not yelling,just emphasizing
I Have done this and had excellant results.An electrofrog turnout is advantageous here and i would wire it for power routing as per the Wiring handbook.
If the S curve works for you great.As equipment wears in,you may find things change some.Consider easing it now rather than later as a preventative measure. I hope this helps,Lord knows ive needed a ton of it over the years , and still do
