What means "Rivet hot"?
Discussion in 'Tips, Tutorials & Tools' started by Lemures, Sep 9, 2006.
  1. Lemures
    Lemures New Member
    Hi, im making a model of Italeri Sturmgeschutz IV. In instruction i read, that some of the parts have to be riveted hot, but i dont know how to do it. I have no special tools fo it.
  2. thewoodengraver
    thewoodengraver Active Member
    That is a mistery to me. Could they have been talking about the actual construction rather that the cardmodel instructions?
  3. Lemures
    Lemures New Member
    I think i should make that part hot, for example with canlde and than put that part there, the part will stick together without glue, only with help of warm.
  4. modelincard
    modelincard Member
    For clarification, is this model paper or plastic?
  5. Brian_Va
    Brian_Va New Member
    Plastic for sure. I've built Italeri panzers in the past. Hot blade the sprue/stud nothing special.
  6. hpept
    hpept Member
    Brian won the prize.:grin:
    Yes, you have to heat the blade of a screwdriver, and then, with major care, melt the plastic rivet until it forms a mushroom head. Remove quickly the blade and let it cool down, making sure that the parts you've joined are able to pivot neither too thight, nor too loose.
  7. GT5500
    GT5500 Member
    I built a 1:9 Revell model of a Ducati motor cycle and you have to hot rivet all each individual link in the chain:mad: the finished result would have looked great if I wasn't 13 at the time although messy it did function as a chain. The links were about 2mm long!!!!
  8. Brian_Va
    Brian_Va New Member
    I won something? (looking around)
    I reckon this calls for some pics of my tanks.
