What is the Smallest Radius a 6 Axle Diesel Can Negotiate?
Hoss
189
TEXAS
I'm in the layout planning stages and I have a couple of curves that are 13.75" radius. Will this cause problems for my Kato Dash 9's and SD70MAC's? If so I'd rather fix it now than after I have track in place. I'll be using easements so that will help, but I still want to know before I start laying track.
Also....even though I've also asked this in another thread....will these locos negotiate the PECO small radius turnouts (12" radius)??
Hoss
189
TEXAS
I knew Kato advertised that their 6 axle diesels would run on 9-3/4", but I didn't think they actually would! I guess that pretty much answers my question.
Hoss
189
TEXAS
I don't plan to have anything as tight as 7-9". In fact, I'm trying to find a way to make my 13.75" radius turns wider. The only place I have it is at the dogbone ends of my turnout where the benchwork is 3' wide. I've got it double tracked at those locations with the outside track at 15" radius and the inside at 13.75". I just want to make sure the 13.75" will work if I have to leave it like that. Everything else is 20" or greater.
hemiadda2d
162
Cheyenne, WY
www.railimages.com
13"r should be more than enough for even the 90MACs. But autoracks may give you trouble--restrict them to the outside main.
Anything 15"r+ is best for autoracks. Besides, the overhang of an autorack on a 13" r curve will knock other adjacent trains off the tracks, on curves......... *speaking from experience!*
Agatheron
317
Mississauga, Ontario, Canada
That's wise counsel... I've been considering doing my first layout based around the auto industry in Southern Ontario. It's pretty obvious that Auto Racks are a part standard trains in the area. The problem for me is space. I've been developing plans to fit on doors mostly to try to simulate the industry. However, if I also want a continuous loop, the trains will need to turn around in an appropriate space. So far, I've been working with plans with a minimum radius of 11" for the inside loop. Given my spacial limitations, the outside loop will be 12.5" to an absolute maximum of about 14". Even with that I'm as close to the edge as I am comfortable with on my outside loop... Realistically I could possibly push the exterior loop to around 13.5" before I have less than an inch between the edge of the track and the edge of the board...
Any suggestions? Or do I simply try to keep autoracks on a reasonable display and make sure that I am careful when running other trains beside autoracks?
My Kato SD40-2 and Mikado runs fine on 9 3/4 " as long as I use curved sectional track (Atlas) - the gauge is wider (but still within NMRA spec) and forgiving. When using Atlas flexible track (code 80) the SD40-2 had trouble on both 9 3/4 and 11". Checking with a NMRA track gauge showed the flextrack gauge to be just slightly too narrow.
marc gast
123
Grand Rapids, MI
hometown.aol.com
6 Axle Radius
Hoss,
Don't run it on anything less than an 18 inch radius. They may negotiate a smaller radius, but, look hokey! From the looks of your layout plans, etc. this looks like a very nice design. Don't ruin it with tight radius, etc. When you get less than an 18 inch radius and running long engines, passenger cars, auto carriers, etc. it really looks toyish with all the overhanging of the rails. Looks like you have plenty of room for wide radius; don't hokey it up! Also, think about the transition into the curves, don't go straight then whan into the radius. Using transision curves makes for nice running and looks more prototypical.
Marc
Hoss
189
TEXAS
Re: 6 Axle Radius
Originally posted by marc gast
Hoss,
Marc
Hey Marc.
When I originally started this thread I was working on totally different benchwork and a totally different track plan than the one I'm in the process of building now. Due to the space constraints on it, it was going to require a maximum radius of about 15" to 16" at each end to turn trains around.
I dismantled that benchwork because I could never settle on a track plan I liked (sharp curves being part of the reason for that).
The layout I'm now working on...and probably the one you're referring to...has a MINIMUM mainline radius of 21", and that is only on the circle at the bottom where the coal loading operations are going on. The rest of the mainline radii are primarily 24" and 30"...with one curve being 26" and one being approximately 42".
I also plan to ease all of my curves....so no need to worry about me hokeying it up. ;)
Thanks for your comments. :)
marc gast
123
Grand Rapids, MI
hometown.aol.com
Curves
Hoss,
Thanks for the update!!!!!!!!!! Sounds like some really nice prototypical running. Ya put your right foot in, ya put your right foot out, and do the Hokey Pokey! LOL
Keep us posted on the progress.
Marc:thumb:
