What is Laser Cut?
Discussion in 'Scratchin' & Bashin'' started by Christopher62, Feb 13, 2007.
  1. Christopher62
    Christopher62 Member
    I know this may be self-explanatory, but what exactly is a "laser cut" model? And what makes it so special or different than a regular cut model?
    Thanks guys!
  2. bigsteel
    bigsteel Call me Mr.Tinkertrain
    laser cut means exactly what it says,laser cut.normally laser cut models are MUCH more detailed than plastic models.and most laser cut models of wood which is normally more expensive,laser cut or not.
  3. jetrock
    jetrock Member
    Christopher62: A "laser-cut" model is one where the cutting of the wood or other parts is done by an industrial laser rather than by a mechanical method, like stamping dies or saws. Typically laser-cut kits can be very precise and detailed, due to the highly controllable nature of computer-controlled laser cutters. They are also easier than other "craftsman" type kits, which often include plans with uncut pieces of wood to be cut at home by the hobbyist, and are thus both more precise and easier to build.
  4. MasonJar
    While the definition of "laser cut" is good, I would suggest that the ease of assembly of laser cut kits is not automatically easier than other "craftsman" kits. Ease of assembly depends (no matter what the material) on good design of the kit/structure, rather than the way it was manufactured.
    I assembled a backwoods engine shed that was laser cut, but in my opinion the design could have been better. Some aspects took full advantage of the laser precision (e.g. great windows), but others seemed poorly thought out (e.g. door detail cut right through, walls cut right through when battens would be glued over top anyway).
