What goes into your maintenance train kit?
Renovo PPR
Just a Farmer
Dec 23, 2006
544
Somerset County PA
What equipment and supplies do you keep around to keep your trains in top running condition?
I have a kit just for my trains and I include the following in it.
Light machine oil. Lionel and even 3&1.
Grease such as Lubriplate.
Dry Powder Graphite.
Track cleaner and alcohol.
Small bottle with a needle cap.
Toothpicks.
Cotton Q-Tips.
Clean cotton cloth.
Small set of screwdrivers.
Small pliers, including needle nose.
Dental type picks.
Soldering gun and solder.
Multi-Tester.
Wire and bulbs for testing.
Spare rubber traction tires.
[FONT=&quot]Spare bulbs.[/FONT]
N Gauger
1:20.3 Train Addict
Dec 20, 2000
6,732
South Eastern, PA
mywebpages.comcast.net
Kit??? Kit???!!!! KIT?!?!?!?!?! sign1 sign1 sign1 sign1
You're supposed to have everything in a "kit"???? ~ not spread out all over the workroom and layout in some sort of perverted "Organized Chaos"????? :eek: :eek: :eek:
That must be what I'm doing wrong :D :D :D
Let's see - Looking all around and under and in between....... the mass quantities of collectible junque i have scattered about........
Light machine oil. Got it - 4 different grades for the Climax in a box on the workbench, contains modeling cement, putty, jet glue and wood glue and Dry Powder Graphite.
Track cleaner and alcohol. -- Yep - Alchol is on shelf where errant elbows cant hit it, with the Goof Off (universal spray paint "from hands" remover) - Track Cleaner is on the bench - and the other bottle is on the layout - it doubles as smoke fluid for the Climax.
Small bottles -- strewn about filled with everything from ballast to water/glue mix.
Toothpicks. - in G??? Not!!! Miscellaneous paint brushes - used for gluing, dusting and some painting too. goldtoth1
Cotton Q-Tips. ~ yeah - and as soon as I find them, I'll put them "Someplace else, where I'll never lose them" :D :eek:ops: :D
Clean cotton cloth. - nope, but i do have about 20 rags, that i use and abuse - then wash and start over :D
Small set of screwdrivers. and a real screwdriver that I use for poking, prodding, prying and every so often i screw in a screw, because I have a...
Cordless drill - Used for everything I possibly can use it for :)
Small pliers, including needle nose., Diagonal cutters, mini channel-locks, miscellaneous pliers of all shapes and sizes
Wood clamps, about 40 for clamping and gluing my many wood projects
Hack Saw for track and light wood cutting.
Multi-Tester. Also have a Capacitor Checker - checks for continuity
Misc. Small parts for many different cars and loco's I have taken apart over the years - i keep all the parts so i can re-use them on a future project.
Hundreds of pieces of wood, in every shape and size for building
Pieces of plexi-glass for building
Pieces of aluminum strips, misc craft beads and lengths of wooden dowels in most diameters.
Wire.... Hundreds of feet of wire - all different colors and gauges.
----- I think that's about it - This is an idea of the "on hand" stock i keep so when i decide to build something, i can concentrate on the ideas at hand, not what i need to go out and get :) :)
Ralph
Remember...it's for fun!
St. Paul, MN
Good lists of useful stuff! I think I have most of those items....SOMEWHERE on this disaster I call my work bench! Hmmm, resolution for 2007: get organized! :)
Ralph
N Gauger
1:20.3 Train Addict
Dec 20, 2000
6,732
South Eastern, PA
Ralph
Uhh Ralph... Wasn't that your resolution for Last Year??? :wave: :D :wave:
Oh - I know - - You were actually organized for a short time in 2006, then you let it go...
Yeahhhh That's the ticket!!!sign1 sign1 sign1​
nkp174
1,455
Cincinnati, O.
I rarely run trains now a days. I don't really have much track to run right now at my home, and I rarely get home to my dad's layout...which has fallen into disrepair.
I do have everything on that list, plus the addition of an extra transformer for solving the classic problem: it runs when I touch leads to the motor....but it doesn't when I place it on the tracks :curse:
Edit: forgot to add super glue. It's unbelievably handy when dealing with brass.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Additional items:
Rolling stock cradle to hold upside down locos.
NMRA wheel gauge and back-to-back gauge.
Track cutters.
Spare nuts and bolts in common sizes (2-56, 00-90, whatever)
An X-acto knife with a triangular grip so it won't roll. And a sharp blade.
Definitely a spare power pack or transformer.
Relic
366
Nova Scotia
Due to my constant condition of terminal poverty I never did work a coupler gauge into my budget I started with a piece of flex track and have used the same GP35 to set all my couplers, works so far.
