What are the symptoms of a burnt out engine
Discussion in 'RC Offroad Forum' started by Justin_E, Sep 14, 2004.
Thread Status:
  1. Justin_E
    Justin_E Member
    What are the symptoms of a burnt up engine? I think mine might be..........
  2. dj6666969
    dj6666969 Active Member
    Running really hot, needle settings are way off then what they should be,runs poorly. How is the engine running?
  3. redheat
    redheat Member
    No power and chasing the timing is a real good sign, RED
  4. dj6666969
    What do you mean by chasing the timing?>
  5. redheat
    redheat Member
    That basically means having to constantly change the carb. settings [more than you usually would ] to keep the engine running , you see lack of compression means plugs that dont last, carb. settings that work at one temp. but not another and there for are always changing, inother words very hard to keep tuned, RED
  6. Justin_E
    Justin_E Member
    Well those sound like what my engine is doing, Im gonna take it in to the LHS and see whats up.. Thanks
  7. redheat
    redheat Member
    Hope it can be fixed , good luck RED
  8. dj6666969
    well if your engne is bad and you dont have enuf for a brand new 1 or the wasp .18 just buy a rebuild kit for it, piston,sleeve and on...
  9. Justin_E
    Justin_E Member
    well the rebuild kit is 60 bux so i might as well just save 40 more for the wasp
  10. dj6666969
    verry true!
  11. redheat
    redheat Member
    You well not be sorry, RED
Thread Status:
