What adhesive can I use????
77railer
267
South Carolina
I need to know what adhesive I can use to hold foam onto a smooth table but later when I have to take it off will not damage the table? Help yall this is to be done before wednesday.
77Railer
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
Can you clamp it? Put a 1/4' ply square under the clamps so they don't damage the foam (or the table ;) ).
The only other thing I can think of besides Doc's suggestion is latex caulking, which can be pried up later - but at what cost to the table I do not know...
Andrew
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
I would think that hot melt will melt the foam and not work too well. My suggestion might be to use double-backed tape. Either the kind with the foam core or if both surfaces are flat enough, use the thinner stuff called carpet tape.
77railer
267
South Carolina
Its a table like you would find at convention centers with the fake wood tops that the legs fold under. Yall have given some good suggestions though. Thanks.
77Railer
