Weird steam locomotive
Collyn
202
Canon City CO
www.rankinrevolutions.com
I caught apart of this show featuring all sorts of trains. One that caught my eye was this train that takes turists to and across victoria falls. The track is extreamly lite weight so the loco has to have more wheels to spread out the weight. These pics were captured from the video so they are not very good.
artur_p
17
it looks like the 4-8-2+2-8-4 Garratt from South Africa.
viewphoto.php
viewphoto.php
viewphoto.php
Triplex
1,719
Calgary, Alberta, Canada
Garratts were quite common in many African countries and also found in Australia and even the UK. In general, it seems that railroads that emulated British practice in the steam era used Garratts when they needed articulateds, while railroads that emulated US practice used Mallets.
nkp174
1,455
Cincinnati, O.
Actually, it was very common here in the US to spread out the weight of a locomotive to reduce the axle loadings.
Take for instance a C&O 2-6-6-6, they actually out weighed the UP 4-8-8-4s, yet had 2 fewer axles. The result was the heaviest axle loadings of any locomotive ever built...and the ultimate machine for wearing out track. (That coupled with the penalty from grossly exceeding the total weight (a danger with bridges), the Lima Locomotive Works cheated in the scale house and lied about the total weight to avoid trouble with the C&O. It was eventually discovered when the Virginian ordered their "light" alleghanies that were quoted at a higher weight the C&O alleghanies...and the ensuing settlement with the C&O caused Lima to lose money on the 2-6-6-6 design.)
An excellent example of utilizing lighter axle loadings was what occured north of the border. The Canadian National, which was similar to our Conrail, utilitzed 4-8-4s to reduce the axle loadings on it's sub-par track while the well built Canadian Pacific utilized 4-6-4s.
Btw, the Beyer-Garrat pictured would be a meter gauge locomotive. They also have berkshires & such. If I recall, part of the design was to keep some of the weight from the water on the drivers, but the downside is that if you need to start a train without much water, you have a lower factor of adhesion.
Note: a Factor of Adhesion is the ration of the weight on drivers to the tractive effort. 4.0 was considered ideal. A locomotive with a low FoA will slip alot...especially when starting a train. The N&W class A's actually had their tractive effort reduced (limited cutoff) in order to help improve their factor of adhesion. It doesn't matter how powerful a locomotive is if it slips to much to start a train.
EDIT: the well known large US steam engines...Big Boys, Challengers, Yellowstones, Alleghanies, N&W Class As, and such were NOT mallets. A mallet recycles steam while these super power locomotives generated enough steam to not need recycled steam.
Dragon
137
Western NY
www.dragonmnt.com
<quote>the well known large US steam engines...Big Boys, Challengers, Yellowstones, Alleghanies, N&W Class As, and such were NOT mallets. A mallet recycles steam while these super power locomotives generated enough steam to not need recycled steam.</quote>
Wasn't the definition of a Mallet one that takes the exhaust steam from the high-pressure cylinders and puts it through a set of low-pressure cylinders?
No matter HOW MUCH steam these big locos generated, don't they still take the exhaust from the rear cylinders and put it through the front set?
bigsteel
Call me Mr.Tinkertrain
Dec 12, 2006
1,319
Cincinnati,Ohio
i thought all articulateds used the leftover steam from the rear cylinders to power the front cylinders.i have a book on it ill look it up later.
Triplex
1,719
What was very common? Mallets (well, actually, most of them weren't "true" Mallets) were the preferred type of articulated in North America. There were no Garratts here.
South African railways are 3'6" gauge.
slekjr
213
to Ohio
www.kiskijunction.com
I was under the impression that Mallet designed the hinged locomotive and that we had both simple and compound types here in the US. The compound being the ones that reused the steam in the front drivers, hence needing larger pistons.
Omber
13
Calgary, Canada
Garrats were extreemly popular in Africa and to some extent in Australia I believe due to the massive power they produced on relativley light axle load (remember that most of African and Australian lines are to these days 3ft 6in lines not standard gauge running modern trains at high speeds of 80kph and units developing horsepower that is similar or same to that seen on standard gauge RR's in North America.
Jim Krause
1,270
Polson, MT
slekjr is correct in his comment about mallets, simple and compound. There is a video available about a Beyer Garrett that was bought in South Africa and returned to Great Britian for use on a tourist railroad.
Omber
13
Calgary, Canada
Sorry :) I didnt know the detailes but I did read about Garrants being the preveil type in Africa and Oceania, so I just wrote what I read :) While on the topic - has anyone ever seen any model Garrats for H0 scale ?:)
Jim Krause
1,270
Polson, MT
There is a company in Great Britian called Backwoods Minatures that either has or will have a narrow gauge Bayer Garrett available.
