I am using the WS realistic pourable water on a stream. It seems as the water is dyring after the pour i am getting shrinking, i am not seeing any leaks under the layout. Anyone else have this happen? Paul
It shrinks quite a bit. I notice mine has been shrinking progressively. I used it for a stream of rushing water over a bed of gravel so it still looks good.
It has shrunk enough that I will need to dry brush more areas to indicate foaming. I still like it for that purpose, it really looks good oozing over rocks . Also don't let anything you don't want in the water fall on the surface. The Realistic Water will slowly engulf the object.
