water drop test
Discussion in 'RC General & Getting Started' started by vette_7t9, May 18, 2004.
Thread Status:
  1. vette_7t9
    vette_7t9 Member
    How is it done? Is the drop of water put on the engine cooling head or in the glow plug area? And how long should the count be for the drop to evaporate/boil off? 3 seconds? 5 seconds? :S
  2. vgsrc
    vgsrc New Member
    the area around the glow plug is where you get an accurate read. it should take the water or spit a few seconds to sizzle off. if you put water or spit and it sizzles in a second, then you are too lean. but listen to experience and go with a digital temp gauge; less hassle and more accurate. save spit and water
  3. dj6666969
    dj6666969 Active Member
    if you dont have the money you can do the spit/water but I just do it on top of the engine head it pretty much will give the right results
  4. redheat
    redheat Member
    Purchase a temp. gun takes all the guess work out of it .:D
  5. dj6666969
    tru but if you dont have much money the water test works just fine. The time is about 10 seconds or so
  6. rcosmax
    rcosmax Member
    10 seconds is a long time and may be on the rich side. the general rule is about 5 seconds for the water to evaporate but not sizzle. i have checked this against temp guns and it seems to be about right.
    hope this helps
  7. pimp
    pimp Active Member
    what is a water drop test and how does it work
  8. redheat
    redheat Member
    Having a 22.dollar temp. gun is cheaper than replacing an engine or a gallon of fuel. Stick with a temp. gun or borrow a friends.
Thread Status:
