walther's caboose needs MTL couplers.
HPRL
83
SW Ohio
You will need to know the manufacturers name for both your cabooses. Then go to http://www.micro-trains.com/00_conversions.htm and look up the coupler numbers. Sometimes it is easier to buy the trucks & couplers together to ensure proper fit. You can probably buy just to couplers for a replacement. Either way you go, instructions will be included with couplers. Any HBS should be able to get you the couples. Or you can try a good on line store like 4NScale, Brooklyn Locomotive Works or N Scale. If you do not see the manufacture then send MTL and email with what you are trying to do. They usually get right back with recommendations. Good luck.:wave:
