Jim Krauzlis
This was an excellent model designed by our own "seawolf" in 1:700 scale. I was honored to be sent the model file and finally got around to trying her out...and she was an absolute joy to build! I was at first a bit leary about joining up the conic sections, as I had not had much luck with them in earlier builds, but this design has extremely well fitting parts. There is still quite a bit of room for improvement in my modeling technique, (and when I do this type of construction again I will try to use a little different technique to line up the edges better ) so the ridges you see in the model are my doing, not the design itself. As I put the sections together I was happily amazed at how exact the fit was...it just went a bit astray as I used my ham-hock fingers to glue the pieces up. ops:
I did use a bit of artistic license in some parts...the original design did not have the forward dive planes and I added scopes as an added detail. Besides the choice of color scheme (I checked the on-line sources and it seemed to me these attack submarines are all off-black, without a red underbelly, but I could be wrong about that too! :roll: ) the rest of the model is the great work done by "seawolf" in designing this model.
I found it helpful to use paper strips, about eight of them in all, along the inside of the conic sections to help guide the edges together...you can image how worse off the construction would have looked if I had tried to free form them without the strips as a construction aid. :shock: Next time I think I will use more of those guides as there were still a few spots that the edges were off because of my bad eye and finger control.
The pulse-jet propulsion housing was something I had not seen before, but, as with the rest of his design, Seawolf was right on...I just hope I did his great design justice with this build.
I built this over the last three days a few hours each night...a great little project and, because of the superb design, a real treat to build! Now I can't wait for him to finish the Typhoon model!
Cheers!
Jim
Cheers!
Jim
