USS Enterprise - from A to E in same scale
PachezZ
3
Hi guys. Which enterprises are best for build in same scale ?
I think 1:1700 will be good,
1701-A : Chris Magnells rescale of Shunichi Maniko's A - it is 1:1700
1701-B : Clevers? What's scale of it? are there any others ?
1701-C : Clevers again? original scale?
1701-D : Clevers or ninjatoes ? scale?
1701-E : i have one, don't know author nor scale, its 27 pages of parts and 7 pages of instructions in jpg...
It will be great if anyone can help me, thanks...
Millenniumfalsehood
640
123
Ark City, Kansas
1:1700 would be a good scale for the Enterprises.
1701-B: If it's Clever's it is *definitely* bigger than 1:1700. It's more like 1:850 scale.
1701-C: Not sure if it's Clever's, but if it is, it's approximately 1:1400 scale.
1701-D: Again, not sure if it's Clever's, but his is also 1:1400.
1701-E: This is probably Zoushu's Sovereign, and if you have the second version, then it's 1:1700. If not, it's more like 1:1400.
You should be able to tell if it's Clever's model; he always signs his name on the title page and has a warning page as well.
PachezZ
3
Thank you, I have Clevers B,C and D ... just didn't know the scale.
for E - I found it's version 3 - which is actualy downloadable from Zoshus site, He says its about 50% bigger then v.2
Maybe I will try to rescale it by measuring saucer section.
So, i will star today with A... It could be nice "timeline" for my new apartment :)
D-WHALE
Utopia Planitia Engineer
Aug 25, 2007
485
405
Schwedt/Oder, Germany
As the man, who has built all the Enterprises and reworked the ships from Clever, i can the following say:
-ENT-A (original from Makino) is in 1/1000
-ENT-B (original from Clever) is in 1/1000, but not really buildable
-ENT-B (reworked from me) is in 1/1000 (not available online)
-ENT-C (original from Clever) is a little bit bigger than 1/1700, also not really buildable
-ENT-C (reworked from me) is in 1/1700 (not available online)
-ENT-D (a work from Clever and me) is in 1/1700 (available on Clever´s site)
-ENT-E (version 2 from Zousho) is approx. in 1/1970, but i have a version in 1/1700
-ENT-E (version 3 from Zousho) is approx. in 1/1220
-NX-01/02 (original from Clever) is much bigger than 1/1700 (i guess also 1/1000) and not really buildable
-NX-01/02 (reworked from me) is in 1/1700 but only for hardcore people (small parts!!!) (available on Clever´s site)
Fact and important: you must print out the sheets on an A4 page and (/or if you have US letter size) not with the printer option "fit to page"!!!!!
you can also measure the size over the saucer if you use the reference sites from Ex-astris:
http://www.ex-astris-scientia.org/
and Gilso´s shipschematic:
http://www.strekschematics.utvinternet.com/fleetchart/mainfleet/mainfleet.html
Greetings
Marko aka D-Whale
PachezZ
3
Ok here I am. Finally I decided for 1:1000 scale, so A will be about 30cm, D about 60...
first I am building "A". I added some details - layering - on nacelles, pylons etc.
It could be cleaner I know,
some more layers, top, side, bottom... Could be cleaner but its better then flat box
Layered "exit"
This is better than flat paper...
2 more layers and 3D dome here.
I made this bottom part the right way - narrow at the back end.
But now, I have problem with pylons - they were bending down under the weight of naceles, so I cut them off and need to figure out simple solution, Thinkink about bended wire or somethink like that...
