Used Delorean Wanted, Running or Not
Discussion in 'HO Scale Model Trains' started by Doc Holliday, Sep 24, 2004.
  1. Doc Holliday
    Doc Holliday Member
    As a result of a suggestion made by a fellow modeler, I have decided I must find an HO scale Delorean. I've spent some time looking on the web, but haven't been able to find one at 1/87th scale. Best I can do is 1/66. Anybody know where I can get one? It doesn't have to run.
    Thanks, Doc
  2. Ho Modeler
    Ho Modeler Member
    Does this car have anything to do with a time travel diorama??
    I dont think they make a Mr. Fussion that small.
  3. Doc Holliday
    Doc Holliday Member
    Actually, in a way it does. I'm modeling a start up line running between the cow towns of Bovee' and Defiance, in the western USA, circa 1880. I'm also employing a good dose whimsey and figured the rear end of a modified Delorean sticking out of a barn would be an interesting scene to model. Unfortunately, I don't think one is/has been made in HO. I may have to scratch build one.
  4. Glen Haasdyk
    Glen Haasdyk Active Member
    If it's just the rear of a delorean that you are after try starting with an 80's camaro, it at least has simular tailights and I know a 1/87 model was made of that
  5. Doc Holliday
    Doc Holliday Member
    I can find 1/66 scale and was considering using that, but if my math is correct, that's over 125% of what it should be. Might work if I was modeling
  6. RailRon
    RailRon Active Member
    Couldn't you place your 'Back to the Future' diorama detail in the foreground, while the RR track passes in the background?
    This way you had a sort of forced perspective, like some of us use to do with N scale structures in the background of a HO layout.
    In this case your barn should be built in 1/66 scale, too. But that's almost exactly S scale (1:64) - perhaps there are appropriate kits around if you don't want to build the barn from scratch. Perhaps the LPBs could be a problem - or are there S scale plastic people around?
    I think this is a really funny idea for a Western diorama! :thumb: :thumb: :thumb:
