use for computer disks?
Discussion in 'Getting Started' started by UP_STEVE, Jul 6, 2003.
    UP_STEVE Member
    I just thought i would ask if anyone has made any good use of computer disks in modelling? i was thinking if someone had an excess of them they could be used for something.
    i have used them on my layout, the tunnel portal in my photo is a disk cut along the line where it is sort of depressed where the label goes. if that makes sense :) im pleased with the result.
    anybody else done something with them?
    just thought i would share :D maybe i gave someone a good idea.
    i also use them as a paint pallete sometimes.
      File size:
      27.6 KB
  2. N Gauger
    N Gauger 1:20.3 Train Addict
    Neat idea!!! But Disks are a little small for G scale. LO
    I like the idea of pallets though - next time i wear out a CD-R - it's going to become a mixing pallet. :) :) :D :) :) for epoxy or paint..
  3. billk
    billk Active Member
    Re: Cool
    I don't know about that, I've still got some 8" floppies lying around!:D :D
  4. Tyson Rayles
    Tyson Rayles Active Member
    Target Practice :eek: :D
  5. RailRon
    RailRon Active Member
    Don't know where I saw this (was it on the Gauge? :confused: ), concerning CDs - CD-ROMs or CDs or CD-Rs:
    Use the portion of a jewel case where the CD sits plus the CD itself as the the center bearing of a small covered turntable.
    Covered turntables were used whenever a hole wasn't convenient, e.g. a freight car turntable in an industrial setting (you wouldn't want to fall the workers or a truck into the pit! :eek: ). Or in a mountain setting, where the pit always was filled up by snow in the Winter. This way you hadn't to dig out the snow again and again. :cool:
    I never saw one of these on an American layout, but in Europe they were quite common. Here's a pic from a German layout. Freight cars were turned by hand and then pulled into the plant by hand or sometimes with a little help from a truck.
    I didn't try it so far, but I'll give it a try as soon as my tracks near the spot where I need such a turntable.
  6. RailRon
    Here's another covered turntable, this time in a narrow gauge engine terminal. But it proves the point: With a CD as a base such a turntable could be built up - as long as you got small lokeys! (Wouldn't be ideal to build a Big Boy-size table! :D)
    BTW: Don't know where I got this pic from - could it be a South African or Australian loco? Can anybody help?
  7. belg
    belg Member
    How about using some old 45's for a larger covered turntable. If you can find an old phono player for them you have the motor and the table all in one.
  8. ezdays
    ezdays Out AZ way
    OK, how about using a 78 for G scale?:rolleyes:
  9. RailRon
    Ok belg & ezdays, but then I would recommend to throw in a handful of gears to slow down the turntable.
    Otherwise visitors wouldn't know if you're modeling an engine terminal or a helicopter base! :D :D :D :D :D
    But in earnest: On a H0 club layout I saw a turntable made of an old 78 phono player - looked great! As far as I remember it was hand operated. (Sorry, have no pics :( )
  10. billk
    billk Active Member
    And sound effects! :D
  11. UP_STEVE
    UP_STEVE Member
    good idea guys :D
    i like the idea of a record player turntable... slowed down of course!
    ron, i think the loco in your pic might be south african, it dosent look like any aussie loco ive seen... but i might be wrong
  12. shaygetz
    shaygetz Active Member
    I use them when I need something for an HO door track or gutter. Just cut along the edge using a staightedge and utility knife (an Xacto isn't up to the task).
    As for turntable motors, in my line of work I have access to these. It's a low RPM motor used in electric fireplaces that come in two voltages, 12 and 120. At 3v the 12v model does less than 2RPM. The 120s are still in my lab being tested but, at 120v, they're good for 16RPM. I have to replace them when they start a low buzz sound, annoying in a fireplace but perfectly tolerable under roadbed and scenery.
  13. TinGoat
    TinGoat Ignorant know it all
    Hey, how about...
    Old VHS video cassettes?
    I was noticing that there is a part of the VHS video cassette tapes that has a kind of diamond tread/grid pattern embossed on it.
    It could make an interesting material for making industrial walkways in larger scales...
  14. rcwatkins
    rcwatkins Member
    ohhhhhh look at those colorful barrels! :p
  15. shaygetz
    [I never saw one of these on an American layout, but in Europe they were quite common.
    I only know of one American prototype but no doubt there are more. Inside the roundhouse that now houses the B&O Railroad Museum in Baltimore, MD. It's a beauty and scales out to not much larger than the Atlas turntable currently on the market.
  16. TrainClown
    TrainClown Member
