UPDATE On N4 and Snap Relays
Discussion in 'N / Z Scale Model Trains' started by kf4jqd, Oct 18, 2006.
  1. kf4jqd
    kf4jqd Active Member
    Well people. I found a problem in using the Atlas snap relays. You need to use both thottles to control the train as it crosses the switch track. This means the other train must be off! I thought I could use the other throttle to do that. I can't. So I will be adding SPST switched to the handheld controls I will be making. I am trying to keep the wiring harness to a minum, but that's not going to happen!:curse:
    There is a light at the end of the tunnel!:D I will NOT have to buy more snap relays to control my signals!:thumb: Last night after work. I ordered a couple of signals from Sunrise. I'm adding the connections in after this posting!
    Andy :wave:
