unusual layout more pictures added
I have just started an unusual layout design. I have some ideas for scenery but I am not sure if they would work out or not. I am still in the construction stage and only got half of the first level done. There will be ten levels maybe eleven if I have the room for it.
Here is a pictures of the basic layout design.
This is the risers and I placed track in were the shelves will go for the tracks. The outisde shelves are 6" the inside are 3" The three top ones will be 6"
This picture shows more of the layout. This is still only one third of the area that is going to have scenery on it.
My son started some scenery but nothing is glued in place yet, it has to come out for me to put the track in behind it. The scenery is going to for looking into the section not from above.
I was thinking about changing the scenery in each section. The one section would have the factory and some buildings. The next section would be a mountianous terrain. On the other side of the mountain would be plains. I don't want to cover or hide the track for no more then one of the sections at a time. I want to be able to see the caboose of the train when the engine comes out the other side. Would changing scenes like that be all right or would it look weird?
I know it is unusal layout I wanted a layout that took a long time to run from one end to the other also I would be able to run about 8-10 trains without worrying about them running to each other. I also wanted to model different seasons on the same layout. I am starting to think I should play it safe and treat it as one layout and build a mountain up to the next shelf and save the top shelves for industries.
Thanks for any advice or ideas for scenery.
