Union Pacific BIG BOY 4-8-8-4 1/48 Scale
Discussion in 'Gallery & Designs' started by kooklik, Feb 20, 2008.
  1. cgutzmer
    cgutzmer Guest
    Superb! Following your designs is truly inspiring!
  2. willygoat
    willygoat Member
    I was snooping around here (1st time in quite a while) and saw your build thread. I said it on the other forum, but I have to say it again. WOW!!!!!!!
  3. Art Decko
    Art Decko Member
    Lordy! Can't wait to see this in paper! Magnificent work! :)
  4. kooklik
    kooklik Member
    Very thanks for all kind words. I first unrolled the frame. Have to divided to be 2 sections. Tender's lenght in 1/30 is 420mm. It's too long to fit in A4 lenght.
    Best Regards
  5. cauesousa6
    cauesousa6 New Member
    jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop jawdrop
  6. Millenniumfalsehood
    Can I ask a question(actually two questions, this being the first. :wink: ):
    How does one texture in Rhino? All I can see in your pics is a gray locomotive with line art on the surfaces.
  7. kooklik
    kooklik Member
    Test build
    Hi there
    I cut first part. 190 grms is rather too thin for making a frame. But the frame is not completed yet. Still more parts will be added to make it stronger. The sample was printed in white and sprayed in gloss black.
  8. Mark_1984
    Mark_1984 Guest
    Only one part cut, and it's already looking very impressive !!!
  9. kooklik
    kooklik Member
    Hi Millennium
    If you mean making texture on the surface such as rusty , oildirty. I'll do it after unroll in Rhino. Then export to photoshop in many layers (contour , pattern line , marking , numbering ect) then adding colors and weathering. For Bigboy it would be gloss black for most skin and parts. Some part will be light weathering added on Super Heat section (the front of boiler) and stove.
    Best Regards
  10. Lex
    Lex Dollmaker
    Just to add to Kooklik, Rhino has a -rubbish- support on UV textures so I wouldn't recommend even try using them in Rhino... As Kooklik pointed out Photoshop does a much better job anyway
  11. hmas
    hmas Member
    Hi peeples
    I am about to commence a quick poll, on the Big boy loco, as to which scale you would like it to be produced in.
    this is one of a few polls to be started on other sites to gauge (pun) interest.
    This poll may not reflect Kookliks final decision, but will give him an idea.
  12. hmas
    hmas Member
  13. kooklik
    kooklik Member
    Hi Tony
    Thanks alot for making a poll survey. During the waitig the poll result. I still continue doing on internal former designing. The frame which I did is rather weak. This is my improved internal former. Basic concept is copied from U-Boat's but added narrow bars beside. These bars maintain the skin plates be wrinkleless.
  14. hmas
    hmas Member
    I thought it may help make me some money!:mrgreen:
    But so far no-one has offered a bribe,:twisted: so I think you should make it in 1/200 scalesign1
    I have a couple of polls running on the model train sites as well
  15. bclemens
    bclemens Member
  16. hmas
    hmas Member
    I'm being asked to enter a password.
    Is that your entry point to edit items?
    Or to keep the riff raff out?:mrgreen:
  17. bclemens
    bclemens Member
    Oops! I forgot to set the album as "public". Should work now. Thanks!
  18. kooklik
    kooklik Member
    Thanks alot Bruce :thumb:
    These pictures are very good resourece for me. There's still some details those I have not put in the 3D model yet.
    Now I'm cutting the internal frame. Sorry for no have any picture posted.
    Best Regards
  19. kooklik
    kooklik Member
    The poll is closed. 1/25 is the winner. I'll unroll in 1/25.
    Thanks for all votes.
    Best Regards
  20. kooklik
    kooklik Member
    Tender's Internal Former in 1/25 scale. All fit in A4 size on 1mm cardboard.
