Union Pacific BIG BOY 4-8-8-4 1/48 Scale
Discussion in 'Gallery & Designs' started by kooklik, Feb 20, 2008.
  1. kooklik
    kooklik Member
    Hi to all
    Finished all front brake links. Very tough work ! Some parts I modified their shape to be buildable by paper. But links machanism is same as original.
  2. cgutzmer
    cgutzmer Guest
    WOW! This is looking super! Not evensure if I wold have the guts to tackle a wheel assembly :)
  3. Nando
    Nando Designer Extraordinaire
    more wheels ....
    what do You think about to reproduce this transporter for Your BIG BOY: ... wheels, wheels, wheels, wheels, ....a lot of wheels to reproduce :mrgreen:
    Very astounding design, I'll follow your progress...
    Your are THE MASTER! :thumb:
  4. bugman72
    bugman72 Member
    I am SOOOOO glad that someone is tackling this project. I tried about a year ago and failed miserably. I have been in love with this loco since I was a little child. Good ole #4006 is just a couple of hours from me at the Museum of Transportation in St. Louis. I've spend many, many hours sitting inside the cockpit of that magnificent beast. Bit of history on #4006...it logged the greatest number of miles of any of the 4XXX locos...1,064,625.
    At 1/48, if my math is right, the loco and tender should be about 2'-9" in length (132'-10" x 1/48 ). I think I might have to resize this to 1/24 to make it a bit over 5'-6" in length.
    Also, is it just me, or did one of the axles under the mover decide to give way in that pic?
  5. bclemens
    bclemens Member
    I wouldn't doubt it...according to Union Pacific Big Boys this thing weighs in at 540,000 pounds!!!
    Kooklik, if you want to make your model to scale weight, all you'll have to do is add 11,250 pounds of lead. :eek:
  6. Nando
    No, isn't You, the axle was realy broken.
    More pictures here
    Best, Nando :wave:
  7. 72BMWR75/5
    72BMWR75/5 Member
    How often do you see a locomotive going across a crossing without being on the tracks?
  8. kooklik
    kooklik Member
    Hope the Prototype BIGBOY won't break my shelf like this pic.:mrgreen:
  9. roch
    roch Member
    Awsomely kool kooklik. :thumb: Can't wait to see more.
  10. iis612
    iis612 Member
    Wow is just not enough!
    Incredible talent, incredible task.
    I can not wait to see more.
  11. kooklik
    kooklik Member
    More about Big Boy , just finished "CrossHead" (a joint between cylinder shaft and Side Rod)
  12. Kezn
    Kezn pwned in the dawn
    look great kooklik !
    waitting to see more.
  13. cdavenport
    cdavenport Member
    Wheel dimensions
    If the U-boat, which I purchased, is any indication, we should be in for a real ride with the Big Boy. One request, if possible Kooklik, include actual dimensions in your drawings for items such wheels, boiler covers, gears, and other round parts. It saves the time of having to build them.
    I have tired of assembling round parts which look clunky in paper anyway. As an alternative, I have begun turning masters on a lathe, making a mold in RTV, and casting them in Celluclay.
    Hey, it's paper!
  14. kooklik
    kooklik Member
    More about design progression.
    Sliding Rail and Reverse Gear
  15. The Hermit
    The Hermit Member
    i was thinking ah damn steam train <= tank
    this thing is freaking neat
    mount a gun on it and i want one......
  16. kooklik
    kooklik Member
    You've made me remember out a scene from "Enemy At The Gate". They mounted 2 T-34 terrets on a bogy infront of the steam engine.
  17. The Hermit
    The Hermit Member
    excellent so i can expect that as a extra in the kit correct 8P
  18. yaniv
    yaniv Active Member
    hi kooklik what a great work u make on this one
    i realy like it
    how u make the nice 3d coluring pic ?also how u make the black and whait pic?
  19. If you design it I will build
  20. kooklik
    kooklik Member
    3D see through color mode is a normal feature in Rhino4.0
    press ctrl+Alt+G (Ghost Display mode) your surface/polysurface objects will be see through.
