Union Pacific BIG BOY 4-8-8-4 1/48 Scale
Discussion in 'Gallery & Designs' started by kooklik, Feb 20, 2008.
  1. WOW This thing is awsome and breath taking at the same time. Can't wait to see what is next!!!!
  2. kooklik
    kooklik Member
    Step back !!
    Hi to all
    It seemed no any progression in serveral weeks ago since I finished the tender truck. I found some problems about the structure strength. Wheels , chassis and bearing are too weak. They were deformed cuased by the model weight. I used too thin paper for load receiving points. I re-designed those parts in the many weeks.
    I found many problems during assemblying the suspension sets to the chassis. Less space , unable to see some points ect. It would be better if separate the tank from the chassis.
    Chassis is the the first new design section. All parts are made from card board. I think this should be enough for heavy weight loading.
  3. shaygetz
    shaygetz Active Member
  4. kooklik
    kooklik Member
    The pictures of damaged parts
    Bearing deformed
    Damaged bearing's hole (loosen)
    Wheel deformed
  5. kooklik
    kooklik Member
    New designed wheel. Internal frame added for better strength
    Tender-151.JPG .
  6. kooklik
    kooklik Member
    Fitting test with new bearings.
  7. cgutzmer
    cgutzmer Guest
    amazing work!
  8. shaygetz
    Wow, do you cut these parts by hand, or do you have a pattern cutter of some sort?
  9. kooklik
    kooklik Member
    All cardboard parts I cut them by hand. For thin paper I cut by sticker cutting machine.
  10. shaygetz
    Excellent workmanship...I've just called my broker to roll all my assets over to Xacto knife blades...:mrgreen::thumb:
  11. sakrison
    sakrison Member
    Watching this model take shape is almost as much fun as building it!
  12. MauricePoison
    MauricePoison New Member
    Sale of model
    Hello, how splendid achievement.
    Do you intend to sell this model when it is completed, as underwater.
  13. kooklik
    kooklik Member
    Hi MauricePoison
    I'll release as a commercial kit. But still very long from now.:mrgreen:
  14. CCT70
    CCT70 Member
    Silly question, from someone who doesn't know much about card modeling, but what do you use for glue for something like that?
    This sticker cutting machine, is it what we call a "plotter" or "Vinyl Cutter"? I have one, and often wondered if it'd cut cardstock like this.
  15. kooklik
    kooklik Member
    Hi CCT70
    Thanks for asking.
    For the glue , I use latex glue for ordinary paper joining. But in some points which need extra strenght such as wheel frame I use super glue.
    For the sticker cutting machine. Yes as you've mentioned, it works as a plotter too. But my machine can cut 230 grms for maximum thickness. All cardboard (1mm thick paper for the frame) I cut it by hand.
    Best Regards
  16. 4x4paper
    4x4paper Member
    And if I may what is the brand for that plotter ?:oops:
  17. N Gauger
    N Gauger 1:20.3 Train Addict
    great Work!! really looking good!!!!
  18. kooklik
    kooklik Member
  19. 4x4paper
    4x4paper Member
    Thanks I will look into it:wave:
  20. kooklik
    kooklik Member
    Finished all wheels last week. And back to the chassis again.
    I spent a few weeks to find suitable materials for making rivets. I found nothing here. Finally I returned to paper. I'll explain by picture step by step.
    Making 2.0 mm paper rivet
    1. Make a punch. Use O/D 2.0 mm shaft and grind the tip to be round shape.
    2. Make a die by punching the rounded shaft to a soft plastic or aluminuim bar. In the picture , I use PE 300 (a grade of Poly Eurythane).
    3. Place the O/D 2.5 mm 70 grms paper on the die. And press by rounded shaft
    4. Completed 2.0 mm paper rivet
