Types of paper...
Discussion in 'Feedback & Support Forum' started by Tintellaar, Jan 28, 2011.
  1. Tintellaar
    Tintellaar Member
    Hiya all, been doing papercraft for little bit now, but run into issues with the very tiny itsy bitsy pieces and the paper separating... I have a question...
    What kind of paper works best? I am using card stock, I think 110 lb, I saw in office depot a 67 lb card... Also, is there a brand or type that is a single piece and will not separate?
  2. Tintellaar
    Tintellaar Member
    Oh, and tools...
    I am using a ham knife for folding glue edges... and some small clamps I got at home depot... but, I need more project focused tools, smaller edges, curved edges to fold and some long clamps... like bar, C, F clamps but in small scale... An extensive search of the internet has yielded very, disappointingly, little... Any suggestions other than starting my own line?
  3. smsuski
    smsuski Member
    I found some miniture clothes pins at a dollar store, I think about 50 for a buck.
    These work for some areas.
  4. Tintellaar
    Tintellaar Member
    Excellent idea, I actually have some, never thought about using them... HA!
  5. ProfessorB
    ProfessorB New to you....
    Inexpensive clothespins can be cut, narrowed, pointed, flattened, and shaped to fit in odd places. Hey, they're cheap!
  6. papperskorg
    papperskorg New Member
    Inexpensive clothespins... Great advise!
  7. cdlc
    cdlc New Member
    Some crafters use hemostats for gripping small things. They look like scissors but clamp shut and are used in surgery. Some hospitals use throwaway ones so if you have friends in the right places...
  8. wulf
    wulf New Member
    I have no experience with clamps, but has anyone using tried two magnets? Seems like they would be quite adaptable. Rare earth magnets would probably be plenty strong even for big jobs.
  9. kevmeister
    kevmeister New Member
    Thanks for the info i was looking the same info
  10. actias
    actias New Member
    Thanks for the info
  11. inky
    inky Member
  12. brivette007
    brivette007 New Member
    I've always used 110lb card stock. Never thought to use clothes pins. Should save my fingers from getting stuck together!
  13. Tintellaar
    Tintellaar Member
    Ok, next question... when cutting the forms... do you cut directly on the line? just outside, just inside?
  14. janeah
    janeah New Member
    About the clamps. I have been using scrapbooking for ages now and I must say I don't have all the necessary tools they advertise on TV or internet. I use tweezers when gluing some items. They have smaller edges and is perfect for papers. :))
  15. Zathros
    Zathros Guest
    Having been a machinist (toolmaker), I can assure you that you may find yourself able to design the tools you need if you give a little thought to it. :)
  16. Haereticus
    Haereticus Member
    I used to use a glue that was fairly watery until it dried, and I would hold the pieces together with the forceps (i.e. tweezers) from a dissecting kit, which worked pretty well. If the glue is quick-drying, you should be able to hold it for long enough. It is also good for aligning the edges precisely!
  17. Jeffrey1773
    Jeffrey1773 New Member
    Great information! Thanks!
  18. Johndhs
    Johndhs New Member
    I cut to the outside of the line. I think it is better to have a bit too much paper than not enough. You can always trim away excess, it is much harder to add paper.
  19. Raj1106
    Raj1106 Guest
    Thanks for sharing these fresh ideas...I never know about some of them...
  20. Zathros
    Zathros Guest
    Just remember, if you cut a part, and it is slightly on the outside of the black line, the black line will show and really stick out on our model. This could be a god or bad thing, depending on the model. Paper edge lines are hard to deal with, and with paper, even harder, because of their necessity. IMHO. :)
