trx 2.5 or hot bodies .18
Discussion in 'RC Offroad Forum' started by monsterrcbuilder04, Feb 13, 2004.
Thread Status:
  1. monsterrcbuilder04
    ive got a t-maxx project goin and i was wondering wat was better a trx 2.5 or a hot bodies .18
  2. mastmec
    mastmec Member
    The TRX has a slide carb with hi and low adj. the .18 has hi adj, no low adj. You'll have to get an old os carb to have both adj. The TRX has more overall power and more RPM. The .18 has a little more torque but not near the RPM. And it's just a cheap motor.
    There is a new small block .21 that just came out if you want a lot of power, direct bolt in.
  3. monsterrcbuilder04
    wat kind of engine is it and were can i get it. im lookin for a good priced engine
  4. mastmec
    mastmec Member
  5. monsterrcbuilder04
    would a OFNA Hyper .21 8 Port Nitro engine be good
  6. mastmec
    mastmec Member
    It's a great engine but you will have to have the conversion kit for the T-maxx.
  7. monsterrcbuilder04
    if anyone has any other suggestions please let me know.
  8. monsterrcbuilder04
    do i need all the parts in the conversion kit.if not wat do i need
  9. mastmec
    mastmec Member
    you would need the basic kit
  10. monsterrcbuilder04
    does the kit just basicly extend the chassis
  11. mastmec
    mastmec Member
    yes, and comes with a engine mount for the big block.
  12. monsterrcbuilder04
    y does it need to be extended? does it have to do with weight distribution or can i just mount the engine back farther on the chassis.
  13. mastmec
    mastmec Member
    The engine (big block) will not fit, it's too long. The back of the engine will hit the rear shock tower and the clutch gear will not line up with the spur gear.
  14. monsterrcbuilder04
    thanks man uve been a big help
Thread Status:
