Trotskiy Planes
Discussion in 'Internet Finds' started by smsuski, May 4, 2005.
  1. newcomer
    newcomer Member
    somehow i'm only getting about two of three notices when someone posts.
    glad i checked - would hate to miss one.
  2. Switched
    Switched Recidivist
    A beautifully coloured Storch is up - fi156c3_sf_v16.pdf. :thumb:
  3. logicman
    logicman Greybeard
    Thanks Matt.:thumb:
    Fieseler Storch!
    That's the one I've been particularly waiting for.
  4. newcomer
    newcomer Member
    did Trotskiy-san skip the Ta 152h ?
  5. Switched
    Switched Recidivist
    No, but he only did the 9 version and skipped the 3. You can see I posted about it several days ago. You have to be quick. :)
  6. newcomer
    newcomer Member
    i haven't been getting all the updates (subscribed) to this forum.
    can you send me the Ta152 ?
    does anyone have the Betty that keeps showing up on his ever-changing wallpaper?
  7. JLKasper
    JLKasper New Member
    Mr. Trotskiy now has the European color scheme version of the Storch available:
  8. Switched
    Switched Recidivist
    Actually, it's fi156c3_ce_v16.pdf that's up. I'd been hoping Trotskiy-san would post both Storch models. :thumb:
    You might need to refresh the page, JLKasper.
  9. JLKasper
    JLKasper New Member
    :oops: Sorry 'bout that. In all the excitement of finding the dark version, I copied the file name from a previous post, and forgot to change the "f" to the "e" in the current version. Since I cacth a new release once every blue moon, I'll probably forget again next time.
  10. logicman
    logicman Greybeard
    Thanks, guys. :thumb:
    I didn't realise there were two versions of the storch from trotskiy.
  11. Artie Bob
    Artie Bob Member
    Trotskiy twins
    Are the Trotskiy twin engine aircraft available, either free or for purchase? There are some (like Lorna and Lily) that do not appear to have been done by anyone else. I am teased as the background to Trotskiy's page rotates through the various twins that he has apparently done. As to versions it seems there are several versions of most types he has designed.
    Best Regards,
    Artie Bob
  12. smyfe
    smyfe Member
    Trotskiy has got the JU-87 Stuka up for download:thumb:
  13. logicman
    logicman Greybeard
    Thank you, smyfe. :thumb:
  14. Does
    Trotskiy intend for the builder to lay the wings flat? It seams that is his intention. I always use Fiddlers method and form an airfoil at the leading edge of the top of the wings but that shortens it a little and I end up cutting off a little from the bottom. I would like to see an option for both methods. All he would have to do is widen the wings a little to allow for the airfoil shape. But I enjoy the simplicity of his designs. I haven't tried flying one yet. You can build one in an hour, how cool is that?
    Thanks Trots
  15. rhino49
    rhino49 New Member
    Just Noticed a different version of the Stuka, one with EP after the Insignia.
    PS Can anybody let us know what squadron these two stuka versions are?
  16. logicman
    logicman Greybeard
    Thank you rhino49. I'd have missed that.
    For those who don't already know:
    When trotskiy puts up a new version, he first puts up the old one for a while. The old version is then replaced by the new.
    This means that, if you miss a particular version, it's gone for good.
    Trotskiy also says that he sometimes posts an old one for only a day.
    He tries to post new models in the displayed order, but if a model is skipped for one or two years, it's not him being perverse, it's the old software.
    Anyone fluent in Japanese, please feel free to correct this.
    (I am only fluent in babblefish and googlespeak) :rolleyes:
  17. charliec
    charliec Active Member
    You can work it out from the fuselage markings - over at one of the regular forum participants can read Japanese so the Trotskiy captions are translated as the new models appear.
    The Stukas are from:
    Staffel 5, II Gruppe, Sturzkampfgeschwader 2 ("Immelmann")(5.II/St.G2) based in Russia.
    Staffel 6, II Gruppe, Sturzkampfgeschwader 3 (6.II/St.G3)
    based in North Africa/Mediterranean(current download)
    Much more detail is available on bases used, etc at The Luftwaffe, 1933-45
  18. So noone wants to takle my question? I get the impression that everyone collects Trotsky's planes but hardly anyone actually builds them or so-it-would seem??? I only say that because I don't see any posts showing actual builds but the two I posted. I was hoping to see some that would blow mine out of the water. You guys are setting the bar way too low here.:p:???:sign1:mrgreen::mrgreen::mrgreen:
  19. cgutzmer
    cgutzmer Guest
    Heh heh - I have actually been mulling over a contest idea. A quantity contest of most models built in a given timeframe. It would consist of any of the small models like Trots, ojimaks, paragons, sprintx etc.... I wonder if there might be any interest in this contest..... plus it would help showcase some models that we rarely see build threads about!
  20. logicman
    logicman Greybeard
    Great idea, Chris.
    Tim: to answer your question.
    Trotskiy recommends you give the wings some dihedral for stability, and curl the trailing edges a little for lift.
    Check this for more info:
    making it fly
    Note that "if it flies 'hurahura' (giddy)" means: if it stalls.
    "Crossing the room, when it reaches the point where you bore the hole through the shoji it is success."
    Shoji = paper screen. :mrgreen:
