trotskiy pdf problems
Discussion in 'Aircraft & Aviation' started by Bionic Modeler, Aug 9, 2008.
  1. If you are getting an error message that your Adobe reader is out of date and you need version 9 try adding this patch to your registry. I tried it and it worked perfectly.
    First cut and paste everything below the dotted line to notepad. Then save it as AdobeFix.reg, then click on it. It will automatically update your regitry and fix the problem. I found this on the Adobe site.
    Windows Registry Editor Version 5.00
    @="C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe"
    @="C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe /u \"%1\""
    @="\"C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe\""
    By the way it is always a good idea to set a restore point on your compter first before making changes. that way if it affects your compter adversely you can go back to how it was. To set a restore point go to Programs, Accessories, System restore, set restore point and click on todays date. Set restore point and you are OK. Then make the above changes.
