Originally posted by Gary H Pfeil
Casey, That first photo is unbelievable. Is it really amodel? The angle, taken looking up thru the trees to the sky, is fantastic. Have you written about how you made them?
Gary, I may have posted the photos and an explanation sometime ago. I don't remember. It's an "age" thing going on...
Anyway, one of the things I do is mix tree varieties and "plant" them as closely together as I can. In the first photo, I have a mixture of "Super Trees" (from Scenic Express) and homemade trees from Sedum. You can clearly see one of my Sedum trees in the second photo.
I do something a little different with my Sedum trees. I drill holes in the trunk and add branches and limbs from other Sedum stalks. It really helps fill out the tree. I also soak the trees in a container of matte medium for a few minutes before adding the foliage. They soak up some of the matte medium which helps preserve them. (That's a trick I learned from Scenic Express.)
One other thing that I do is add lots of "undergrowth" to wooded areas. I have seen a lot of layouts where the "wooded areas" consisted of a few trees and lots of bare ground. They just don't look convincing to me. If you look at the photos I posted, you can see there is a lot of ground cover and brush under the trees.
(The underbrush where I live in the Ozarks is so thick and heavy in the summer that you can hardly walk through the woods. That's the impression I try to convey on my layout. )
