Track Warrants
Discussion in 'Model Rail Operations' started by railohio, Oct 7, 2008.
  1. kutler
    kutler Member
    Pretty darned rare too, unless one is working a branch line on 3rd Trick:p
  2. railohio
    railohio Active Member
    How is that rare? It just means that particular train is going to hold the main and another is going in the siding. Happens all the time all day on every kind of track warrant controlled line.
  3. kutler
    kutler Member
    Please follow the thread
    The comment is based on a prior assertion that typical Track Warrant's were commonly simple. My response was based on experience issuing such authorities. Track Warrants are used to issue supplementary slow orders, give advance notice of condition of main track switches, foremen working on track , opposing trains or trains working and more. The list continues to grow as more items are seemingly introduced to the ever evolving form.
    Ironically going back to the genus of the concept, dispatchers were told that these forms were going to be basic affairs designed primarily for branch line use only. The original concept was to replace operators and agents from hinterland branchline terminals. The system was expressly not for mainline usage.
    T&TO has always been a manual system and early branch line Warrants were also protected manually. It adds weight to the point that T&TO was an easier system that Warrants were not installed on most railroad mainlines, therefore T&TO was not replaced, until a computerized protection system was developed for TW's.
  4. kutler
    kutler Member
    1. Track Warrants and Timetable and Train Order control systems can co-exist.
    Sometimes when TWs were being phased in (often over many years) trains operated using both (or more) systems.
    I.E. A train might originate in a yard where movements are authorized by rule 105 (other than main track) rule and rule 94 Yard Limits (Main Tracks only). The YLs might extend a mile or two onto the T&TO controlled subdivision. The train might proceed to a branchline Jct. at which time it obtains a track warrant to Work for 30 miles on at TW branch. The branchline Jct might be a controlled interlocking once controlled by a local operator (or agent) who's job of copying TOs was replaced by TW, the interlocking now controlled remotely by a dispatcher.
    Track Warrant forms are always evolving
    Early track warrants as developed on various railroads were anything but uniform. To operate on another railroads version of TW one would have to be cognizant of the variations. I.E. on some railroads a patrolling foreman is issued an authority as a train and is thus met. On others the foreman is only issued a permit to occupy the track and the crew must contact the foreman and only proceed after written instructions are received.
    The short point is that one should be aware what forms were in use during the era they are modeling as they changed often.
    What's in a name?
    There is a article in Trains magazine, possibly 1984 about the early history of Track Warrants and Direct Traffic Control the two dominant forms of control that superseded T&TO. Track Warrant Control Systems are related or have developed from other names such as Occupancy Control Systems , Manual Block Systems(Canada), ATCS, probably others.
    One main difference between TWC systems and DTC systems are DTC systems rely on defined limits which are fixed and defined by signage located on the right of way. TWC systems in general have dynamic limits which are not fixed therefore no signage exists in the field to remind crews when the authority ends.
    Some examples of Track Warrants are found at:
  5. acsoosub
    acsoosub Member
    On the shortline railroad in my city they have a "paddle". It's literally a piece of a cut down canoe paddle with the railway's initials engraved into it. Whoever has possesion of the paddle has control of the line. If there is a second train on the line (which is pretty rare but can happen) the second train consults the guy with the paddle on movements. The entire line also has a top speed of 25 MPH outside town, and probably more like 10 in town.
  6. Dave1905
    Dave1905 Member
    This is called a "staff" system and it is a very old system. It is still commonly used outside the US.
    Dave H.
