I don't see where you are from, but another thing that causes problems here in the Southwest is sun. If the layout is in a sun room where it can get direct sunlight, the track will expand during the heat of the day and contract when it cools off. The same is true if your layout room has wide variations in temp. Finally, make sure your track is put together correctly. If you are using snap track and don't get it assembled carefully and tacked down correctly, you can introduce kinks into the track and cause problems.
