Track adhesive
Discussion in 'N / Z Scale Model Trains' started by ls1gto, Dec 18, 2005.
  1. ezdays
    ezdays Out AZ way
    Using white glue is great because it gives you the option to easily make changes as you go. I'd be in deep you know what if I couldn't do that. To answer your question, when you lay the balast, it will loosen up the glued track, but the ballast and the rest of the trackwork should hold it in place until it dries again.
  2. Drew1125
    Drew1125 Active Member
    I just use white glue also…it takes about two hours to cure…I use either map pins or weight the track down with something…
    What I like about the white glue is that it makes a nice temporary bond before the track is ballasted…if you need to pull up, or re-position the track; all you need to do is gently slide a putty knife under it, & pop it up…
    I’ve never been very good with hot glue…I always end up with a mess, &/or 3rd degree burns…!
    I have used liquid nails, & I still use it for gluing together foam insulation board, but it’s on the messy side, too, & it’s just too much glue for N scale track…
  3. ezdays
    ezdays Out AZ way
    We seem to think a lot alike here. I do the same thing, using liquid nails for gluing foam, I don't like it for anything else because it is unforgiving, you can't change it without a mess once it sets, and secondly, if you use a little, the rest gets hard in the caulk gun and you waste most of it.
    You're lucky, only 3rd degree burns with a hot glue gun? I can get that with the gun unplugged:cry:... Yeah, I do use the hot melt glue on some things, but aside from the 2nd or 1st degree burns, :oops: I wind up with glue cobwebs (or are they gluewebs?) all over the place.:rolleyes: :rolleyes:
    With the white glue, as I also said, you can make adjustments to your track or roadbed easilly. I usually soak the track and it comes right up. I've even done that after the tracks were ballasted. Just a few seconds is all it takes. You can't seem to soak the roadbed off, I use a razor saw to pull it up with little damage to either the foam or cork.
  4. CalFlash
    CalFlash Member
    I used adhesive caulk out of a tube to glue flex track to homasote and see no reason it wouldn't work with your combination(s). It's quite fast going but with enough work time for positioning etc.
  5. dwight77
    dwight77 Member
    When you are using the white glue to hold the track in place (including flex track I hope) do you use the glue full strength?....or dilute it?
  6. Clerk
    Clerk Active Member
    :wave: :wave: I use it full strenght but just run a "very thin" bead and pin the flex track to it until it sets.:thumb: :thumb: If you have to adjust the track a trifle after the glue sets, put a very small amount of water on the ties so it soaks into the glue and move the track. You shouldn't have to reglue it. just pin it down until it sets again.
