Tower Pro sg50 servos specs
Discussion in 'RC General & Getting Started' started by rvillaverde, Oct 28, 2005.
  1. rvillaverde
    rvillaverde New Member
    Do you know where to gather some (technical) info about these servos?
  2. dj6666969
    dj6666969 Active Member
    Dimension 40.6mm*19.8mm*37.8mm,Weight 55.2G,Operating speed 0.24sec/60degree(6.0V) ,Stall torque 13.0kg/cm (6.0V), Temperature Range -20?~60?,Dead band width 4ms, Operating Voltage 4.8V~7.2V,Structure Feature 3 pole ferrite, dual ball bearing, 3 metal ears and 1 Resin metal gear, connector wire length: 32cm
    Is that what your looking for?
