tops out
Discussion in 'RC Onroad Forum' started by vette_7t9, May 14, 2004.
Thread Status:
  1. vette_7t9
    vette_7t9 Member
    My stock RS4 with an OS engine tops out so quick. Is this normal? do i haf to buy a 2 speed to make it run fast?
  2. bandit1
    bandit1 Member
    change the gearing on ur clutch or spur gear. since u changed to an os engine, its probobly got more power than the stock engne, so it will top out faster with the same gearing. so try that, b4 the 2 speed, altho the 2 speed is a good upgrade.
  3. dj6666969
    dj6666969 Active Member
    hell no dout switching gearing on the clutch bell and the spur would make it faster, but it would be as fast as with the 2 speed, if money is not a total issue go for the 2 speed youll be alot happier you did so!
  4. pimp
    pimp Active Member
    2 speed and the clutch bell and spur gear would be the best if u have the $ 2 spend
Thread Status:
