Today's Whacky Winners
Discussion in 'Getting Started' started by Mountain Man, Sep 12, 2008.
  1. Mountain Man
    Mountain Man Active Member
  2. 60103
    Same problem as the triplex -- loss of traction as the fuel in the tender is used up.
    I think Bill Schopp made one of the Santa Fe hinged boilers using the threaded bit of a broom handle.
  3. Russ Bellinis
    Russ Bellinis Active Member
    I think the other problem with triplex & quadraplex types was that the size of the firebox reached it's limits in a mallet. They could build bigger locomotives, but they could not build enough steam to power the extra drivers for efficient operation. The Santa Fe tried bellows to hinge their boilers on some of their "Prairie Mallets", but found that water would collect in the bellows and freeze in winter when the locomotive was sitting and subsequently cause leaks and cracks in the bellows.
  4. nachoman
    nachoman Guest
    it is not suprising that these designs werent popular. The reality is double heading is much easier, more versatile, and just plain makes more sense.
  5. Russ Bellinis
    The problem with double heading is that each steam engine required an engine crew to operate it. If the railroads could design a double or triple sized locomotive that could operate with one crew, they could save on labor costs. Labor costs were so low in the 19th and even early in the 20th century that it wasn't an issue, but by the late 1920's & 1930's union contracts were beginning to cause wages to rise. I suspect that the ability to hook diesels into mu consists with one operating crew had as much to do with the end of steam as the lower maintenance costs of diesel.
  6. nachoman
    nachoman Guest
    I think this is also why some a-b-b-a sets wers sold, and numbered as "one locomotive." My guess is they were cautious about how unions would react to crew requirements for these new diesels, and the railroads found a loophole.
  7. Dave Flinn
    Dave Flinn Member
    Practical? Maybe not, but they're still fascinating to look at. Thanks.
  8. Mountain Man
