Discussion in 'RC Drifting and Setup' started by Vinnie, Mar 21, 2006.
  1. Vinnie
    Vinnie Guest
    hi all,
    This weekend I was setting up my car for drifting. So I adjusted the springs and cambers:
    I also taped the rear tires:
    I taped the middle of the tires because I read this somewhere. But when I drove my car I saw that the sides of the wheels had more surface touching the ground. The tape was stil clear, but the sides were dusty.
    So, do I need to tape my whole weels? Do I have to tape my wheels till only the tape is touching surface, or do I have to keep some rubber? Does the car have to run on the tape only or not?
    And I used some electrical tape, but this has a lot of grip. What kind of tape should I use?
    any help is welcome
    grtz vincent
  2. ruther-TT01
    ruther-TT01 Guest
    I use Electrical Tape on my tyres but not in the middle.Its on the outside of each tyre but not to much tape maby twice round.Leave 1/4 of the tyre untouched on the inside .Works well for me.
    Hope this helps
  3. Kenji_Sasaki
    Kenji_Sasaki Guest
    put tape on the whole tire. or use hard compound rubber tires
