The logging area on my mushroom layout
Discussion in 'Track Planning' started by Matthyro, Nov 1, 2004.
  1. sumpter250
    Neat link! Happy to see Nn3 is growing. I'll still have to mostly scratchbuild the shipyard's #1, but then, I had to mostly scratchbuild the HOn3 version.
  2. Matthyro
    Matthyro Will always be re-membered
    No photos but have the track laid and am wiring it at the moment. Still waiting for an order that I placed Internet Trains but nothing came and I asked them where my order is and no response from them.
  3. SAL Comet
    SAL Comet Member
    Loads from narrow gauge cars were often off loaded to a dock or warehouse and stockpiled till there was enough product for std gauge. so both gauges need to use the same track, but at seperate times. Plus the economy of a single track with a third rail vs two seperate tracks.
  4. tillsbury
    tillsbury Member
    Thanks, that makes a bit more sense. Are you therefore saying that any stretch of dual-gauge track (such as the one in the diagrams on this thread) will need an unloading platform and/or storage area next to it to make sense... or are there any alternatives?
  5. TrainClown
    TrainClown Member
    Thoughts From Some Clown
    Hi Robin,
    I've given your track plan some thought and I would like to point out a few things. Let's call it "food for thought." The first thing is by the area at the top of your plan where it says "double track," it also says "sawmill." I think this area is oversimplified. The narrow gauge tracks here should diverge and one line run around the log dump for the sawmill, whether that be into a pond or down a hill. The other narrow gauge track should go and run parallel to your main line, which is the black line in your drawing. I think the main line in this loading area should have a bypass track that runs parallel to the main line and this would be where the cars are stored while they're loaded with fresh lumber so they don't block the main line. Or, instead of a bypass track, it could be a spur that runs into the back of the sawmill at an oblique angle. Lots of stuff to be loaded in this area. You've got two sawmills and a mine, all serviced by this area and undoubtedly you're going to have cars waiting around to be loaded and unloaded.
    Now the business track for the sawmills is what I want to talk about next. That's the lower red line to the right of the drawing. I don't think this track is long enough. When you think about it, you've got two sawmills working off of this area and I think you have a wonderful chance here to build a "catch as catch can," rickety old teetering railway line that snakes much further around the diorama and it could switch back two or three times more. You figure these guys have been cutting lumber for a while and the tracks have grown as they've had to go further to reach the logs. So you could have all sorts of rickety old trestle bridges, bridges made out of logs, cuts blasted through the sides of mountainous areas and large areas that have already been logged off and, of course, at the top would be where the fresh trees are. You've got quite a locomotive operation there with your turntable and locomotive service sheds and the camp, so these fellows need something to do. I think you should extend your track as far as possible.
    I'm going to be adding a mine to my layout, too, but my mine will have its own loop of track and its own little train that runs around inside the mine and emerges from tunnels and skirts the terrain then dives back into another tunnel, only to emerge once again. This way, I can set the mine train going and it adds animation to the layout. I saw this done once with a point to point where the train came out of a tunnel and ended its run on a girder system over the mine where it supposedly dumped its ore. Then the little train would go back into the mine to pick up another load. But I prefer my train to go in a loop rather than a point to point system.
    Aside from this I really like your plan. Nn3 is a real challenge. Perhaps one day I will accomplish it. But for now my mine train will be HOn30 and that's challenging enough for me.
    TrainClown [​IMG]
  6. Matthyro
    Charles, thats what I am planning to do. Have a platform and a covered storage area for trans shipping.
    Thanks fo your well thought out observations TC.
    I would like to have more track but am concerned about over crowding so will see what I can do.
