Test track????
steamhead
2,360
Brownsville, TX
Hi,
My programing track is about 20" long and forms part of my yard. I have it wired with a DPDT switch, so I can incorporate it into the "main line" to check for adjustments I do. If they're not right, I roll the engine back to the programming track & set it to "Program" and do whatever is needed.
Gus (LC&P).
UP SD40-2
2,709
jflessne, on the layout i have now my program/test track is 8'. on previous layouts it was only 1.5'. i don't know what system you are using, but i use Prodigy Advance, so i really only use the program/test track to read the decoder. all programing and CV adjustments i make while the engine/s are on the fly on the mainline:thumb::D. -Deano
brakie
2,827
Bucyrus,Ohio
I prefer a 6 foot long test track.
The reasons are:
1.Creep ability of my locomotives..If my locomotives won't creep 6 foot then I tweak the drive till it does.
2.Freight car rollability..I elevate my test track just enough that the car will start rolling and roll the 6 foot.If the car doesn't roll the 6 foot then its worked on till it does.
When I was using DCC I had a 1 foot test/programing track that I used.
