Terrestrial Voyager
Discussion in 'Science Fiction & Fantasy' started by gippolot, Jan 28, 2007.
  1. gippolot
    gippolot Member
    Next pic.
  2. gippolot
    gippolot Member
    Rodney Matthews uses made up runes in many of his drawings. This are the ones I've draw to put on the sails.
  3. gippolot
    gippolot Member
    next try
  4. Jackrum
    Jackrum Member
    That is a beautiful design... if you need any beta builders please send me a pm I'd love to help.
  5. goney3
    goney3 Member
    Simply Stunning! :D
  6. gippolot
    gippolot Member
    Thanks Jackrum, but pardon my ignorance, what is a beta builder?
    Thanks also to goney 3 and all compliments proceding, much appreciated.
  7. Lex
    Lex Dollmaker
    A beta builder is someone to testbuild the model for you before "official" release~
  8. gippolot
    gippolot Member
    Much of this model I have to dream up my self. This is what I guess you could call the bridge balcony or forecastle.
    Here is one of the doorways to the bridge. The scale I've set as 1:400, so a human, assuming a human or humanoid type drives this vehicle, their height would be 5 or 6 mm. As a previous poster mentioned, Rodney Matthews iincorporates many insect-like features in his paintings. Hence it is rare to see a typical human type character in his images, but their dimentions are approximately similar.
    Here is one of the doors I made for the bridge/balcony/forecastle.
    I mess around with different colours to try and come up with something that pleases me. Then I print it out & glue in place. My latest idea on how it may look.
  9. gippolot
    gippolot Member
    This is the best view from directly behind that I've made up to date. I'm fairly satisfied with the outcome, (I'm refering to the colour), but may change my mind if I feel inclined.
    This is a drawing of what I how I want to install the rudder. I'm still deciding on how to construct the rudder. It really needs to be 3D to give a sense of reality.
  10. gippolot
    gippolot Member
    The suspension is going to be a difficult problem. I can either use something other than paper/card, or go for something stronger.
  11. Zathros
    Zathros Guest
    A beautiful fantasy model. Kind of reminds me of Roger Dean. Who knows, maybe you'll run into Olias of Sunhilow?
  12. Gearz
    Gearz Member
    This is TOP shelf! gippolot.. I have a about a zillion fantasy / SF pic with subjects that I'd love to convert to card models.. You've inspired me to move a few into the 'Maybe not so impossible' basket.
    This is design with a capital D!. Most excellent...!!!
  13. gippolot
    gippolot Member
    Thanks very much for the kind words Gearz. If some of my posts inspire you, then I couldn't ask for anything more.
    That said, here are some ideas I've been messing around with. Early on I'd had a thought that it may be possible to use a card beam to support the hull on the wheels.
    This is a drawing detailing what I'd thought of.
    A jig was made to make a suspension leaf beam from 4 layers of 1.5mm thick card.
    But the card began to delaminate quite quickly once I'd started giving it a stress test.
  14. murphyaa
    murphyaa Designer
    For that spar I'd recommend carving it out of balsa wood (800lb cardstock for purists).
  15. gippolot
    gippolot Member
    My next leaf beam was made from approximately 2 x A4 paper sheets cut into 8mm wide strips and glued together in the jig, just as I'd done with the 1.5mm thick card. This beam was much improved and didn't delaminate as the card had. Also it could be easily sanded to remove any rough edges that had developed during the gluing process.
    Here is a pic of the jig made to try the beam out in.
  16. gippolot
    gippolot Member
    Here is a view with the beam in place as I would imagine within the hull of the model. It seems to sit quite well. All that is missing is a jig to assimilate how the beam would fit inside the wheels, and take the load to prevent the weight of the model from causing the wheels and struts to sag.
    And a view from the reverse side.
    To date I haven't decided whether to go with a laminated paper beam, or use a wood or wire beam instead.
  17. jleslie48
    jleslie48 Member
    well, if it was a real laminated beam like in a covered wagon, you would wrap the beam with a strap/belt of rope/metal/leather to keep it from de-laminating. I would suggest you do the same here with strips of paper, maybe 7 evenly spaced, cinching (sp?) the laminated pieces so they can't de-laminate. also there would be a nail driven through each end so each layer cant slide out, like the spring steel suspension on your car. an end cap should work for that function.
  18. Bowdenja
    Bowdenja Active Member
    Why not put a wire in your lam beam?
    Also what glue are you using? PVA?
    Maybe you should go with a yellow glue designed for wood, because of the stressing involved. Maybe PVA, if that is what you used, can not take the flex stress as well.
  19. Zathros
    Zathros Guest
    I think that a model of this quality deserves an axle that works. I would use whatever works, wood, metal, brass strips. A solid piece of hardwood with the leafs springs carved in. It truly has so much potential. I don't ever recall seeing a model this style anywhere.
  20. Dnlgtr
    Dnlgtr Member
    If you still want the layers to show on the finished arch, what about making 2 narrower laminations(or cutting the lamination in half) and adding card layers Vertically in the center.
    Maybe the Cross-grain will help.
