TC3 gearing
Discussion in 'RC Onroad Forum' started by coolboxerman, Feb 26, 2004.
Thread Status:
  1. coolboxerman
    coolboxerman New Member
    i have a question, i'm running a green machine 3 in my tc3 and my gear ratio is 7.4:1. the problem is that it gets crazy hot, too hot to touch after each run. am I overgearing it?, how many teeth should my pinion and spur be?
  2. mastmec
    mastmec Member
    Is 7.4:1 your final or primary(motor/spur) ratio? What pinion and spur are you using now?
  3. coolboxerman
    it's a 59T spur, 25T pinion.
  4. mastmec
    mastmec Member
    Go back to stock gearing and see if that helps, your motor is a high RPM motor, your running a 2.36:1 primary, I would go much higher, stock first though.
  5. timrock
    timrock Active Member
    how do you figure 7.4:1 ?
  6. timrock
    to get good help,you need to tell me what the ratio is.7.4 to one what.
    count how many times the motor turns to one turn of the drive wheel and let Me know.
  7. mastmec
    mastmec Member
    If you have so much experiance at this, figure it out yourself.
  8. timrock
    thats not nice to tell the guy,mastec.whats you problem?
  9. mastmec
    mastmec Member
    That was for you TIM.
  10. timrock
    well you make no sense coming in here and coming across as if you have experience where you do not.
  11. mastmec
    mastmec Member
    Well the second dumb question you asked was "7.4 to what" which he said in the beginning, TO 1.
  12. coolboxerman
    the motor turns approximately 7.4 times to make the drive wheel go one full revolution.
  13. mastmec
    mastmec Member
    One other thing is to check the drive train for any binding and make sure the pinion gear is not too close to the spur.
  14. timrock
    ok 7.4 is very low gearing.you are not over geared.
  15. timrock
    man with them small wheels and a 7:1 wheel to shaft ratio,you must have hardly any top end speed.
  16. coolboxerman
    well, i use my rc to run over friends' xmods mostly. I usually give them a head start then accelerate and run over their xmods. Man, so much fun doing that
  17. timrock
    well if you are enjoying it then thats what matters.7:1 ratio? your TC3 must be pretty quik off the line.i bet,you just hit it the trigger and it is Gone.
  18. mastmec
    mastmec Member
    OK timrookie, 7.4:1 ratio is at the top of the gearing, one more pinion size and it will be maxed out, he's geared for top end. Where do you get off telling him that he's geared very low.
Thread Status:
