t3 and tc3 problems? help!!!
Discussion in 'RC Offroad Forum' started by ty007cars, Feb 15, 2004.
Thread Status:
  1. ty007cars
    ty007cars Member
    i have a t3 and a tc3....i noticed they both are going slower and slower.i put a aluminum shaft in my tc3. please help me whats wrong?????? thansk ty
  2. mastmec
    mastmec Member
    We can't see it, you'll have to be more specific. What are you doing different?
  3. Steve M
    Steve M Member
    Have you given your electric motors any service? The armatures get scored after time and the brushes likewise go off.
  4. ty007cars
    ty007cars Member
    i changed the brushes, i cleaned the motor with motor spray.i run both of them when its cold out?
  5. timrock
    timrock Active Member
    you might not be charging your cells right.with nicads,if you fail to charge them right,they can develope `memory`,not perform as well and continue to get worse from lack of correct charging.that would make your cars run slower and slower.
  6. ty007cars
    ty007cars Member
    i use 2400,3000 ni mh cells,i also race?
  7. timrock
    i think your 2400 pack is a nicad.
  8. ty007cars
    ty007cars Member
    i just look and it was a matched ni mh panaconic cells, i dischard both of my batteries,but my cars both went fast....then droped in speed and acceleration?
  9. timrock
    there must be someting you are useing in both cars.what is it?
  10. ty007cars
    ty007cars Member
    in my tc3 i have a novak cyclone,hitec servo,d4 11x2 motor,airtronics fm radio system.t3 i have a f1 pro reverse,orion core 12x2 motor,jr servo,airtronics radio system.
  11. timrock
    do your cars share battery packs?
  12. mastmec
    mastmec Member
    How are you charging and dicharging and storing you batteries, what charger are you using.
  13. ty007cars
    ty007cars Member
    im using the 2400 in my tc3,the 3000 in my t3.i use a dynamite mega peak charger..i got it 2 years ago.
  14. mastmec
    mastmec Member
    Are these the only two bateries you use, how old are they and how often do you use them?
    Also do both cars roll smooth with the pinions out of the cars, is there any binding of anything.
  15. timrock
    both cars are having the same problem.must be somthing your doing wrong or somthing that the cars both share.
  16. mastmec
    mastmec Member
    It's sounding more like the batteries are not up to par anymore, or the charger is false peaking.
  17. timrock
    i would say it has somthing to do with the batteries/charger too
  18. quinnjere
    quinnjere Member
    I say that the voltages are different and the volateges are relative to the rest of the cells, maybe there is a dead one slowing you down. I would take out the voltmeter.
Thread Status:
