T28 1:25 DrafModel
Status
josve
620
579
111
61
Odda Norway
Another kit from DrafModel. DrafModel has proven to be one of the best designers.The Pak40 and the LeFh are both something I call a 100% kit.
Everything fits....no need to trim any parts. very few designers can beat this.
So my expectations for this T28 are really high. I will also give a lot of thanks to Rafal for this great model!!
When starting a new model I also have a chance to clear my workshop a bit...
First pic shows the desk at the final stages of the P51...second pic shows present stage!!
So the build starts with a fresh workbench.
The hull was first out.
Drawing
Frames put together. This will as we can see be a big model :)
misacek
9
Marylan, USA
Nice clean desk . Maybe you should post a pic of your desk in about 2 days. sign1 Make sure you take a pic with current newspaper showing a date . sign1
Every time I clean my work area it takes less than a day to mess it upp again .
Good luck with T28 . Love your work with other previous models .:thumb::thumb::thumb:
josve
620
579
111
61
Odda Norway
Continuing with skinning the hull.
Also started on the front hatch, that looks like an escape tunnel!
Parts to fit in the gaps under the upper leadwheels....I'm going to need an awful lot of nuts....
And some nuts....needed :)
josve
620
579
111
61
Odda Norway
Thanks Igor!! The advantage of DrafModels is that everything fits :)
Some stiffeners for the skirt.
Paint isn't dry yet....I paint with Humbrol 105, hope that is close enough....
josve
620
579
111
61
Odda Norway
Not brave....I just have some spare patiente to use :)
Started on the turret.
The drawing
The assembly of the frames for the main turret went very well.
Next was the top skin that will be covered on the sides with another skin part.
Top skin is on, and the flips are bent over the rounded edge and glued.
Next was the side skin....the other part will be glued tomorrow.
All stiffeners for the sideskirts are done.
And in between I'm placing nuts and bolts......
J
Jim Nunn
Johnny,
Another outstanding build, the model must need several hundred nuts to do the added detail.
Jim Nunn
josve
620
579
111
61
Odda Norway
A lot of nuts....and a skittload of wheels.... I have to do something with my motivation when the wheelbuild starts :)
josve
620
579
111
61
Odda Norway
Hi Peter!!
Not much for an update...but some turretwork is done :)
Two turrets done
Closer look at the main turret
Delicate laserparts for the grids!!
josve
620
579
111
61
Odda Norway
Front turret machinegun port.
Drawing
When I looked at the drawing the port first looked a bit tricky to make.
It's half way sunked into the turret.
I cut out the parts and glued the 3 pieces together.
I also had to cut a hole in the turret to have the port fit in.
And when I put the piece in....of course it fitted :) hey! it's a Draf Model!!
Gun and outer plate mounted
The main hatch.
Now I got use of the tiny screws I got a year ago!!
Hatch mounted in place.
josve
620
579
111
61
Odda Norway
Hello guys!!
Continuing this build after a little...break :)
Did some work on the turret today.
josve
620
579
111
61
Odda Norway
Ok...last day at home before i go to work tomorrow, and will be away for 2 weeks out in the north sea
Some progress made on the T28
Did the front cannon and the left air intake this morning
Reactions: mysteroid
9,551
Wow! That is awesome. I can imagine banging my knee against it and swearing, it look so real! Those intake vents are amazing! :)
josve
620
579
111
61
Odda Norway
Hello guys!
Back from the north sea for some days now, and have been doing some paperworks.
Engine fan. This is going to be covered, so i did not put a lot of work in detailing here...
Finished the turrets and machineguns. Started to put on some weathering and dirt and rust pigments. It will be smeared more out when its finished...
Will continue on the exhaust
Status
