T28 1:25 DrafModel
josve
620
579
111
61
Odda Norway
Finally the long awaited T28 from DrafModel was ready!!
The kit is very thick....It contains 36 pages!!
The model is the Soviet medium multi turret tank that was produced between 1932-1942.It looks like DrafModel has done it again!! The kit looks very promising and it also seems to be holding the same high standard as the PAK40 and the LeFh18/40.That means a 100% fit kit!!
Since this kit has no interior,the insructions are limited.
They cover all neccesary parts in a very good 3D presentation.
The first 5 pages are 3d drawings
We can also see from the drawings that this isn't the easyest model.....
The following 4 pages are formers and rolled parts.Most parts are to be glued to 1mm cardboard (unless you have the laserparts)
I'm not sure about the partscount on this model,but it seems to be a lot.
The parts are well organized so that you don't have to look through a lot of pages to find the parts you seek.
The tank can be built in 5 different versions.
With different parts and markings for each type.
Wheels......hold your breath.....74 of them all in all!!
First the drivewheels
The upper leading wheels
Roadwheels.Two types of them.
Tracks.
Only individual tracklinks or lasertracks available.
For the individual links, each link contains 17 parts.....
Tracks are also printed with metallic print.Both glossy print and satin print for you to choose.
Laserparts.
Frames and tracks are available.
Saves a whole lot of work.....
From what I have seen in this kit.....DrafModel has done it again!!
The kit looks incredible good and a "must have" for every vehicle/tank guy in the cardmodel business.
The only drawback I can see is that there is no weathering on the model.So I'm going to add some dirt and rust when I start the model sometimes in the beginning of next year.
cbg
indianapolis (fishers)
Johnny,
I know of no one on this forum better suited to making a nice report of this new model. Looks like lasercut is the way to go for some tedious parts.
Tanks and armor are not my thing in general, but I do like watching your technique and construction expertise (I own an old VW, so I found your Schwimmwagen report very interesting).
Good luck on those 74 wheels. . .
cbg
