Switch tracks
Discussion in 'N / Z Scale Model Trains' started by pupparo, Feb 6, 2003.
  1. pupparo
    pupparo Member
    Does anyone make a curve switch track that is compatible with atlas 11 radius track?
  2. MCL_RDG
    MCL_RDG Member
    As I recall...
    As I recall Atlas made curved switch tracks at one time.
    Where they are now- well- they thought that N would take off at the time- about 20 years ago- prolly found out that they weren't big sellers- then!
    The way things are goin'- if Atlas won't re-introduce them (and believe me- they have people researching these sites for marketing schemes) someone else will. The question is- can ya design around it, or are ya willing to wait?
    I say design around it and lament what could be or forget the lament and run trains.
  3. MCL_RDG
    MCL_RDG Member
    I can't think of an model RR where curved switched weren't required!!! HO-G-N, I ran 'em all!
    <-------Makes note to contact manufacturer- We are turning trains in corners of our spare space- where's the beef??? (read as curved turnouts, so curved turnouts can feed yards typically coming off curves!!!!)
    Gee I think I just padded Atlas's bottom line by 1.8M (estimated time to market- 3 years).
    You heard it here first!
  4. redracer
    redracer Member
    Tomix make a curved point with radii of 280 & 317 mm. Don't know you would go incorporating it into a layout of another type though ...
  5. Drew1125
    Drew1125 Active Member
    Peco flextrack & turnouts are compatable with the Atlas flex & Atlas Snap Track...& they make curved turnouts....not sure about the radii, though...if I were you, I'd give them a try.
  6. csxnscale
    csxnscale Member
    Peco both code 80 and code 55 has curved turnouts.
    In N-scale :
    Outside radius 36", inside radius 18".
  7. jdh
    jdh Member
    fleischmann has curved switches [molded in roadbed] that will work.
    the molded in roadbed is grey, and still maintains the same height as the "no roadbed" atlas track.
    joiners work on both brands.
    i don't remember if these are 'selective' or not.
    if they were, i wired around them so i can't tell.
    mine are 10+ years old
