stuck piston
Discussion in 'RC Onroad Forum' started by asher, Jul 6, 2004.
Thread Status:
  1. asher
    asher New Member
    Hey guys i was driving my rc car last night and it suddenly stopped....the flywheel has pushed out into one of the belts....now the piston is stuck....and suggestions?? its a kyosho V one S....i have taken the engine out and played around with the gears but i cant move the pullstarter at all....the piston is stuck....
    Thanks
  2. redheat
    redheat Member
    If things came apart could be a busted crank bearing or two. If you can remove the back plate and take a visual, how much fuel have you run threw your motor?
  3. asher
    asher New Member
    Hey, yeah i have taken it apart and the crank has snapped....thanks for your help
  4. redheat
    redheat Member
    So what now a new crank or motor?
  5. asher
    asher New Member
    A new crank....
  6. dj6666969
    dj6666969 Active Member
    damn how the #@$% did you manage to do that?
  7. redheat
    redheat Member
    I would think that if you damaged your crank it had to damage the engine block and your bearing have got to be trashed, I would take a very close look at that motor before deciding on a crank.
  8. asher
    asher New Member
    Actually its the connecting rod....still i dont know how that managed to push my fly wheel out and slam the clutch into the gears.....messy stuff [V]
  9. redheat
    redheat Member
    Check those bearings real good Im sure there is some damage done.
  10. asher
    asher New Member
    Hmmmm yeah i have checked the bearings and they seem to be fine? its really strange....
  11. redheat
    redheat Member
    Did you get your parts and if so are you up and running?
  12. asher
    asher New Member
    yeah i have just ordered the connector rod and i should have it up and running very soon...thanks for your help.
  13. redheat
    redheat Member
    After you get it runnning drop a line let us no how it turned out for ya, later, Red
  14. asher
    asher New Member
    will do man!! ciao 4 now
  15. redheat
    redheat Member
    So whats the latest news ,any luck yet?
Thread Status:
