strange loco running
Discussion in 'N / Z Scale Model Trains' started by sirrab, Sep 9, 2013.
  1. sirrab
    sirrab New Member
    hi All,
    I hope someone can help me. I have a atlas loco class b23-7 which is running strange. when I run it it doesn't always move but if it does and i run it at any speed it will start at this speed and then it starts to slow down and speed up and finally stops. It can't be the track as when i use a push pin in front of it so it can't move this still happens.
    Any idea's anyone please :)
  2. steamhead
    steamhead Active Member
    Is this a DC or DCC loco..??
  3. sirrab
    sirrab New Member
    Sorry is DCC :)
  4. sirrab
    sirrab New Member
    new info,
    tried running it in one place and noticed the following.
    stops then restarts after several minutes. slows down and speeds up.
    I ran it in one place with a tack in from of it so it cant move.
    strange :)
  5. zathros
    zathros SENIOR Administrator
    Sounds like something is overheating, probably a bad solder. :)
  6. sirrab
    sirrab New Member
    thanks will see what i can find
  7. sirrab
    sirrab New Member
    Thank You yes a bad solder on the decoder. one of the pads
    Thank you everyone
  8. zathros
    Great! Happy you found that. Make sure any grease is fresh because sometimes old grease can cause great resistance and make components overheat. :)
