I was not sure the where the best place for this question/topic was so I figured as it is a technical question of a sorts I would post here.
Well after three days or so I am still having a tough time deciding on what shade of black or possibly a shade of black with a touch of gray in it to use on my steam locomotives.wall1
I have ruled out a straight dark black as it turns the locomotive into a dark shadow under indoor lighting. I was going to go with Polly Scale steam power black but it also seems a little too black but not as bad as engine black. I played around with mixing a little white with black but could not seem to get the look I am after. I always seemed to end up with a little more of a gray look than I wanted.:curse:
I also tried putting a post on the Yahoo CNR SteamMavens group and was told the CNLInes SIG paints ( Scalecoat 1 ) were good. Namely their warm black. But after a few phone calls I found out real quick it is a hard paint to find. Just about all the hobby shops I called do not stock it. The ones I did find who do stock it had no warm black and would only be able to order me some once they had a large enough order of the paints.wall1
My next move was to try mixing up some warm black. I remembered an article in the Nov. 1999 Model Railroader where a Spectrum 2-8-0 was kitbashed into a close look alike of a Central Vermont N-5a. The article had a formula for warm black using 4 parts Polly Scale steam power black and one part boxcar red. My first test mix using their mix came up with a dark brown. After a few more tries and more black than boxcar red I was getting closer to what seemed to be a warm black but it still had a touch more of a red/brownish hue for my liking. After several hours of carefully measured small amounts of paint I finally decided to take a break from paint mixing until tomorrow.
This brings me to my question. Does anyone here have a paint mix they use to paint their steam locomotives with? At this point I am open to suggestions. Maybe I am just being too finicky about the color but finding a black that looks right sure is harder than I thought it would be.
Once I do get the paint thing figured out I plan on posting a thread showing all the work I did to restore and turn the Van Hobbies brass CNR N-5-ds into good running locomotives. It has been a lot of fun so far and I have found I really enjoy working on brass locomotives. My wife says the last part is a bad thing. Not sure what she means by that.
Wayne Reid
Ontario,Canada
Wayne Reid
Ontario,Canada
